Thanks for the heads up, my wife's ***** could have easily exploded destroying her vagine
Just ordered some this morning from Amazon. Will check them out when the arrive. Seller seems reputable but you never know.
I ordered some off Amazon last year, 5 lots of 10's for approx £15.
http://www.amazon.co.uk/gp/product/B00UTGZJGK
If you look at the product pics, they actually look like the fakes in the OP's post, although the item I received was more like the genuine one on the left of the OP's post with BBE dates and the rounded flip etc.
When even the NHS can end up buying knock off drugs it's not surprising that a lot of sellers may be flogging fake batteries with no idea.
That is the same seller I received these from and they are fakes (Awaiting Duracell to confirm) I do not think it's the sellers fault I think they have unknowing been supplied fakes by the supplier.
The 1 & 2 star Amazon reviews also raise concerns on non genuine batteries being supplied tbh.
Apparently a non fake duracell, you should not be able to remove the plastic wrapper?
Unless its just a lot easier to do with a fake vs real.
I got a pack from Amazon and Im pretty sure they are genuine, but I can remove the plastic wrapper with a little force.
I would never buy Batteries off eBay for this exact reason :/
