Hello all,
As the title states I need help with choosing components for my first custom water cooling adventure. I have done some extensive research but still have some questions that were left unanswered on other forums, so I decided to make a thread for it all and see what the wonderful community here can come up with.
Now the aim for the build is performance while still being silent (or as close as possible without sacrificing too much cooling power).
With that in mind I have chosen the following components:
Be Quiet! Dark Base Pro 900 purchased
Intel i7 6700k processor purchased
Asus Formula VIII Z170 RGB Motherboard purchased
Corsair Dominator Platinum 32GB kit (4x8GB) @ 3200mhz DDR4 memory purchased
Samsung 950 Pro 512GB M.2 SSD purchased
Samsung 850 Evo 1TB SSD purchased
EVGA Supernova 1000 P2 power supply purchased
2x EVGA GTX 1080 FE purchased
The water cooling components that I have chosen so far are:
Pump/Res:
Pump: EK Water Blocks EK-D5 PWM G2 Motor (12V DC PWM Pump Motor)
Pump Top: Bitspower D5 / MCP655 Mod Kit V2 - Black Sparkle Finish
Pump Top: Bitspower D5 MOD TOP Clear "S"
Res: Bitspower Dual / Single D5 Top Upgrade Kit 250 (Clear Acrylic Cap)
Res Accessories: Bitspower Z-CAP II With G1/4" x 3 (Clear Acrylic Version), Bitspower G1/4" Black Sparkle Aqua-Pipe II
Coolant: Mayhems Pastel Blue Berry
Blocks:
EK Water Blocks EK-Supremacy EVO - Acetal + Nickel CSQ purchased
GPU Blocks - EK GTX 1080
Radiators/Fans:
HWLabs Nemesis GTS 420 purchased
3x NB BlackSilentPro 140mm PK-PS PWM Fans purchased
HWLabs Nemesis GTX 360 purchased
3x NB BlackSilentPro 120mm PL-PS PWM Fans purchased
Fittings/Tubing:
4x Bitspower None Chamfer Crystal Link Tube OD 16MM - Length 1000mm - Clear - BP-NCCLT16AC-L1000
20x Bitspower G1/4 Enhance Multi-Link For OD 16MM - Black Sparkle - BP-BSEML16
Other varios 90 degree fittings from Bitspower in Black Sparkle
- iiNNeX
Pump/Res:
Blocks:
Radiators/Fans:
Fittings/Tubing:
- iiNNeX
shame. I thought about taking the angle grinder to it but thought twice lol.
