Permabanned
- 25 Oct 2004
So I had my car serviced and mot'd last year and pretty much within months suspected they hadn't done a thing. There were no advisories or issues reported and it went through perfectly fine only needed a £3 light bulb.
Now I knew there was at least 1 thing that needed sorting and that was a nail in the near side back tyre which was repairable. That wasn't noticed or mentioned at all. A full oil change was also done apparently even though 2 months later my low oil pressure light came on when I checked it was pretty much bone dry. I know my car uses about 1 litre of oil per 3,000 miles, certainly not 4.5 litres.
Anyway just had car back in for its MOT/Service and low and behold the list in extensive with over £1000's worth of work needed, CV joints, welding, things that should have been noticed last year.
Question is, can I do anything about it now even though a year has almost gone by. I'm sure if it had been reported a year ago the extent of the work required now wouldn't be any where near as bad.
