The Pascal GTX 1070 Owners Thread
Only an MSI Aero OC 1070 in this, as I plan to swap to a 1080Ti when that's out. But for now, this is the right owners thread for me!
I've just installed my Gigabyte 1070 WINDFORCE OC (2 fan) an hour or so ago. It's dead quiet even at full load. It boosted itself to 1946 without me even touching anything. Ran Valley 1440p ultrawide for 30 mins. Max 63 degree's (room temp 24.5). Had a quick manual OC and seems to hit 2100 without issue. Still running Valley now, Temps 63 on this and I'm stunned coming from a good 980 OC. Rock on.
Only downside is no backplate on this bad boy and the cooler housing isn't solid like my 980 was. It's a non issue for me as I never see inside my case and I've not had any previous sag (had a msi 970 with no backplate and was fine for me)
Seems to me it's a very good silicone lottery with any Non Founders 1070, and that you'll get a good OC from it and be happy. My only issue with some of the Palit cards and "cheaper" branded cards was a weaker warentee and I'm bound to have this card 18 months odd and passing it on with warentee is key and you can't go wrong with Gigabyte returns in the UK.
It's very unlikely I'll ever waste my money on a top end "superblock OC extreme Amped thunderbolt lighting edition with go faster strips and led lighting" EVER. Closed case so on it goes and away it goes.
Still going strong @ 2108 OC on Valley and fluctuations between 62 to 63. Happier days.
The gigabyte 3 fan seems to cost £30 extra over the 2 fan, is it worth it?
I'd imagine it'll be slightly noisier and run slightly hotter, given that it's using the same small fans as the tri-fan version, just with one removed. It also lacks the backplate of the G1. It shouldn't matter too much though, as it's not like the 1070 requires a monster cooler and they all overclock to about the same level anyway.
Sounds like you got a good one :) See how much you can get out of the core and memory on Firestrike Standard, I scored 21750 GPU last night but I would imagine there will be some better clockers out there!
Welcome and on TROH.:)
The Roll of Honour.
Date 06/07/2016, Make MSI Aero OC Edition, Amatyr, Link
Date 06/07/2016, Make MSI Gaming X, divinebeetle, Link
Date 04/07/2016, Make MSI Gaming X, i_am_jon, Link
Date 04/07/2016, Make Palit GameRock Premier Edition, Phil87, Link
Date 03/07/2016, Make MSI Gaming X, V_R, Link
Date 03/07/2016, Make Palit GameRock Premier Edition, foxyfaefife, Link
Date 03/07/2016, Make MSI Armor OC Edition, chris-82, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, razorpakk, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, styuR, Link
Date 02/07/2016, Make MSI Armor OC Edition, Shawreyboy, Link
Date 02/07/2016, Make Gigabyte G1 Gaming, Gripen90, Link
Date 01/07/2016, Make Gainward Phoenix Golden Sample, shrek2, Link
Date 01/07/2016, Make NVidia Founders Edition, BornEvil, Link
Date 30/06/2016, Make Gainward Phoenix Golden Sample, thefogo, Link
Date 30/06/2016, Make MSI Gaming X, Carta, Link
Date 29/06/2016, Make Zotac AMP Edition, Charlatan, Link
Date 29/06/2016, Make MSI Gaming X, Daaaveee, Link
Date 29/06/2016, Make MSI Gaming X, Aretak, Link
Date 29/06/2016, Make Inno3D iChiLL X3 Edition, leerogers00, Link
Date 28/06/2016, Make MSI Gaming X, DougF1, Link
Date 28/06/2016, Make MSI Armor OC Edition, markoboyo11, Link
Date 27/06/2016, Make Zotac AMP Edition, Mangochutney, Link
Date 25/06/2016, Make MSI Armor OC Edition, BornEvil, Link
Date 23/06/2016, Make MSI Aero OC Edition, McGraw, Link
Date 22/06/2016, Make MSI Armor OC Edition, smithy83, Link
Date 21/06/2016, Make MSI Armor OC Edition, Phixsator, Link
Date 20/06/2016, Make Palit Founders Edition, Paul_cz, Link
Date 20/06/2016, Make NVidia Founders Edition, Dave2150, Link
Date 20/06/2016, Make MSI Gaming X, AthlonXP1800, Link
Date 20/06/2016, Make Gigabyte G1 Gaming, w00dy85, Link
Date 19/06/2016, Make MSI Gaming X, kully1972, Link
Date 18/06/2016, Make MSI Gaming X, AliGoz, Link
Date 17/06/2016, Make MSI Gaming X, philo-sofa, Link
Date 16/06/2016, Make Palit Founders Edition, Biffa, Link
Date 16/06/2016, Make EVGA Founders Edition, Daaaveee, Link
Date 14/06/2016, Make EVGA Founders Edition, mankycrack, Link
Date 13/06/2016, Make NVidia Founders Edition, !bluetonic!, Link
Date 12/06/2016, Make MSI Founders Edition, yoyo59, Link
Date 11/06/2016, Make MSI Founders Edition, JamesM, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1070.​
Gbp to usd is 1.29 now! If anything prices might go up if the pound keeps falling through the floor.
It's almost a certainty that goods produced outside the UK will go up in price in the UK as the value of sterling falls. GPUs fit neatly into that category.
My machine is almost 6 years old 2500K at 4ghz (with box cooler, never changed paste), 8GB DDR3 1600 and new Palit GTX 1070.
Here are my results from overclocking via MSI Afterburner, with adding 200mhz on core and 600mhz on memory. I did not modify voltage, only the clocks and power limit. Dirt rally is 1440p all maxed incl. MSAA and advanced blending. Witcher runs 1440p, ultra with shadows medium and hairworks off. Unigine are maxed in 1080p.
dirt rally def - https://abload.de/img/drt_def0ysab.png - 51.5 fps
dirt rally oc - https://abload.de/img/drt_oc9qsbn.png - 59.2 fps
witcher 3 def -https://abload.de/img/witcher3_def7zs1z.png - 59 fps
witcher 3 oc - https://abload.de/img/witcher3_ocmbs8c.png - 67.2 fps
valley def - https://abload.de/img/valley_defrls9w.png - 83.2 fps
valley oc - https://abload.de/img/valley_ocmnsyc.png - 91.4 fps
heaven def - https://abload.de/img/heaven_def5yssf.png - 88.2 fps
heaven oc - https://abload.de/img/heaven_ocpcsv6.png - 98.9 fps
Not bad with a 2500k. Looks promising once I get my 1070. Should be a good deal cooler than my 7970xf, I won't miss the heatstroke although the performance was very good.
Seems that 2063MHz is the best I can do on mine (as a stable clock). Even with 100% on the voltage slider, 2076MHz crashes. Memory is fine at 9.4GHz though, which just tips it over the 300GB/s mark in GPU-Z. Crazy to see regular GDDR5 hitting those kinds of speeds. I wonder how much that'll be affected when they start cycling out the premium Samsung chips for Hynix and *spit* Elpida for later production runs. The Elpida trash on my GTX 780 could only manage 6.2GHz before falling over, whereas earlier 780s with Samsung chips could hit 7GHz without issue.
Anyone got any opinions on Palit cards?
Mine is on it's way.
The Gamerock Premium isn't the best looking card, but the specs are really good. It's one of the fastest 1070's @ default settings, has a dual BIOS, and is supposed to be a very quiet card even when under load (mind you, they're all supposed to be pretty quiet anyway). One of the cheaper custom cards too.
If you aren't too fussed about the slightly odd colour scheme, and can accept the 2 year warranty, then it's got to be a card to seriously consider buying.
Seems like your stable clock is pretty much the same as mine. I could hit 2114/2502 (10ghz!) for a run of Firestrike but for every day gaming and rock solid stability I've backed it off to +110/+600 which on a 1:1 fan profile levels out to 75c and 2063mhz after a few hours of gaming :)
Had a good few hours with my 1070. Getting over 2ghz appears very easy and 600+ on the memory seems so far to be no bother. Very happy with Pascal and the Windforce OC from Gigabyte. Not interested in synthetic benchies, just in game and stable. See how I go through next few weeks. Temps are amazing BTW. Not seen it go above 64 degrees.
I have a Palit Jet Stream arriving Friday. Seemed the best buy at the moment. Decent cooler cheap (well relatively) colour scheme's more subdued than the gamerock.
Was going to pick up an msi gaming x but at £54 less it was the jetstream + a new s.s.d. for me instead.
Just pulled the trigger on the Palit.
Never heard of them until today but just researched it and the good feedback here I went ahead with it, for me its crazy to spend this much on a GPU so I hope I do not regret it. Will sell my 970 to fund half of the cost.
Was going to get a 980ti but that may have needed me to buy a new psu which would have negated the cost advantage.
So I've had my eye on the 1070 availability and prices since they were released in the belief I had lots of time to pick one up due to the fact my Oculus Rift would be at least a month away.
Had a shock yesterday when I received an email to say its been shipped and arrives tomorrow!
I really don't want to pay the currently inflated prices but it looks like I have no choice as currently I'm running a 960 4GB (temporary measure waiting for Pascal).
As I'm now pretty poor after giving all my money to Oculus I'm torn with what to get to give me the best bang-for-buck. I considered a discounted 980TI but I really want a 1070 in the hope that the VR features get implemented and for long term support etc.
I currently have a Gigabyte Windforce in my basket here for £419 (could have bought this elsewhere for £25 a couple of days ago, sob...) which looks pretty good. I fancied the Zotac AMP extreme but that's another £25 on top so quite a jump. Its £10 or so cheaper on a competitors site but I think I'd prefer to give OC my money as they seem to have a great reputation and customer service is important to me :)
Any recommendations?
If I were buying today I would go for the cheapest non-blower style card in stock, which is this :)
https://www.overclockers.co.uk/inno...ddr5-pci-express-graphics-card-gx-068-in.html
They pretty much all can overclock to 2000mhz anyway, anything over that is only giving a minuscule difference in frame rate.
If you want to pay a little more for a design you prefer or a manufacturer you like then fair enough but any performance gain wont be worth it IMO :)
