- 25 Nov 2011
- The KOP
I'm assuming he means nVidia GPUs also draw more than 75watt from the PCI-e socket?
Yeah
Yeah
My motherboard is quite happy running Trifired RX480s so if a M/B can not run a single RX480 it does raise a few questions about the motherboard.
I hate to think how some of these motherboards would get on if they ran power hungry Kingpins or similar.![]()
And all you nvidia fans ignore the fact it happens on Nvidia cards too.![]()
Believe it happens on every GPU the problem here is the crashing depends on the motherboard quality. Cheap motherboard seems to be effected more than more premium quality products.
Normally though those Kingpins, etc. would be pulling that extra load from the additional connectors not the PCI-e socket itself. Even heavily overclocked the draw from the socket is usually under 55 watt on most GPUs.
I don't know what you mean but the 480 is the only known cards that consistently pull more than 75w average from the motherboard under normal gaming conditions
When you are using 4 of them you still have to beef up the power to the motherboard with extra connectors.
Not getting into this back and forth. But I have seen and watched videos showing they is more GPUs that do pull more power. It gets even worse the more you overclock.
YouTube is your friend right now DP.
Pull more power than what? are you talking the 300 watt thing?
Problem is not everyone builds in sufficient margins - unfortunately seems that the better made boards are capable of ridiculously more current than you are ever likely to encounter while the basic 1oz boards are cutting it fine.
Excess current generates more heat which can over time degrade most electronics including interconnects - there is quite a range between nominal current conditions and a short circuit and likewise a range in the effect from long term degradation to burn up in a fire.
I believe MXM is a bit different doing more of the power conversion off board? with around 7 connectors spreading the load over 1 or 2 high voltage pins and several low voltage pins - most of the core is fed from what 4-6x 1.8v rather than the one 12v connection.
MXM is fed a lower voltage yes but that only increases the current that the connector has to deal with.
Failure of AMD fanboys to see facts is strong in this thread.
AMD ****ed up and have admitted it. The consequences for those with the 480's is unknown at this time.
nVidia ****ed up too with the 970, fact and they paid for it.
Did they pay for it?
Are them extra pcie power connectors only needed for 3way+ or summat? I was running 2x290x cards over 1.4v for months before i realised i hadnt plugged that back in. Im guessing its not needed for only 2 cards.
More like they gained from it when people sent back the gtx970's and paid more for a gtx980.
