First watch
Try posting in the huge watch thread.
In that price range, I would suggest you take a good look at Christopher Ward.
Good advice.
Could save a few quid by looking at the steinhart range of divers.
http://www.steinhartwatches.de/en/diver-watch.html
Very well made for the prices. Got an ocean one green here and have been very impressed with it. So much so im looking to add several other models from their range.
These look great for the money. Could I really take one diving to say 30 m and it would live to tell the tale?
That OCEAN One Premium Blue :o
Yep, easily. All the steinhart dive watches are rated for 300m. Im a member of a dive watch collectors group on FB and there are quite a few recreational and professional divers on there who use the ocean series watches.
Wrist shot of my ocean one green.
Very easy to adjust the bracelet as it uses screw in links as opposed to pins. Something not usually seen on lower priced watches.
Evening all,
Going to be going watch shopping tomorrow, I have always wanted a nice one - it will be my first ever one! It will be worn frequently, as I am starting my first 'proper' job in September. Therefore it will need to be smart. I like the Omega Seamaster range, but they seem a little too expensive sadly. I am utterly clueless about watches, so any general guidance, brands to go for/avoid etc would be much appreciated!
Thanks all :)
what's the job I take it it's something where the time to the nearest nano second is important hence the need for an £800 watch?
Most high end watches are manual. Most manual watches are not very accurate. If you need accuracy then get a cheap digital.
For the love of God go second hand, so much more for your money.
£800 will only buy you a crappy Quartz or TAG, jesus wept.
Wrong wrong...and wrong :P
There are some incredible brands in that bracket. The second hand 'prestige' watches will still carry a price tag beyond that for any of the decent models.
Longines, Hamilton and Steinhart are some great suggestions.
/edit for clarity, there are some excellent second hands in that range...but saying he absolutely should go second hand isn't true.
But if you buy a higher end watch second hand then you can sell it for around the same price if you want a change in the future. If you buy one of the cheaper watches new (and I agree there are some fantastic watches out there) then it will lose value the moment you buy it.
Rather than look online and try to absorb people’s opinions, go into a decent jewelers – watch specific if you’re near one and try a range of styles and sizes on your wrist. I guarantee you’ll be surprised at what looks good and what looks ghastly!
The world of watches is a fickle place. You’ll hear people slating brands for not making their own movements and using a standard ETA while charging a premium, you’ll hear people claiming their Tudor is a Rolex but at a ‘better’ price. None of it matters, it’s what suits and appeals to you, even if it a Casio with a calculator on it!
Here’s some reading all the same to fuel your interest
https://www.gentlemansgazette.com/eta-watch-movement/
Why buy a BMW or Merc when a Dacia or Kia will do the same job for much less??
It's a combination of prestige, build quality, design, budget and personal taste. Each individual will have varying quantities of these and they'll choose their wristwatch accordingly, much as people do with cars, computers, coffee makes. I'm sure jas72 has some material vice that others would see as macho & overpriced.
Make sure you know the difference between the different movement types - Quartz, Automatic, Solar etc. Other than that just choose something that you think looks good on your wrist. Seiko, Hamilton, Tissot I'd be looking at in that price range, along with others.
This.
I would first learn the differences between the movements and understand them. Buy something that suits YOU. Tissot and Seiko make an excellent range of watches both Quartz and Automatics that are affordable and extremely well built. Don't jump in at the deep end and spend a couple of grand without understanding what you're buying.
My main daily watch is a Seiko SNDD87 with a leather GT strap. It is gorgeous to look at, very accurate and relatively cheap when I purchased it about two years ago. I sometimes alternate between an SKX007 and a Tissot PRS516 Chrono too.
I have this view on watches. You either go Omega/Tudor/Rolex upwards, or you just get a Seiko.
I would not be spending £1000 on a mid tear watch, often some of these mid tears are worse quality than a Seiko at far less money.
What I would do is save money and get a second hand Omega Seamaster.
These are the sort of things you should be buying, pre-owned with servicing from a respected dealer.
Yes there another £800 out of budget, but save up and when you look back in a couple of years you will release spending more on pre-owned was correct.
http://www.johnpass.co.uk/watches/p...seamaster-professional-diver-254.18.00.0.html
http://www.johnpass.co.uk/watches/pre-owned-stainless-steel-omega-seamaster-2054.50.00.html
