- 15 May 2012
- Louth, lincs
Upto what? And have you tried all timings on auto to see if it will boot at that speed? Imc maybe limiting factor if it dosn't, I take it this is with cpu in your sig?
I'm not mixing though... they're both the same 2x2x8GB G.Skill 3600MHz C15
I assume you mean mixing those with the Kingston? I never had any plans to... the Kingston is only in here at the moment because I didn't have any other DDR4 to hand and wanted to get the right stuff which appeared to be on back order. Once the new stuff has arrived - these Kingston sticks are going back in my server.
Also try setting
Dram ref cycle time 240
Dram refresh interval 65555 (or whatever max is)
Twr 10
Tfaw 20
Tcke 6
Twcl 9
If looking at using these, he will likely need to revert to AUTO in order to establish a daily overclock. A refresh interval of anywhere near that at that density and speed is very much likely to cause corruption when using the system for more realistic periods
Perhaps that's the issue then.
I have a 4x8GB kit of Corsair sitting here in its box - they still posted it even though I cancelled the order. I'm tempted to try it and see if that can boot at 3600MHz.
At 3400MHz I have 13-13-13-32-1T stable at 1.5V which I'm quite impressed by. I was hoping for 3600MHz at 15-15-15-36-1T or better, but 3400MHz at those timings will be quicker.
As long as it doesn't crash with what I'm doing & the performance isn't pushed too far where it starts to degrade and perform worse than a "slower" config... I'm happy.
This seems decent...
win10-3400-15-15-15-38-1 by CosmicLogos, on Flickr
win10-3400-14-14-14-34-1 by CosmicLogos, on Flickr
win10-3400-13-13-13-28-1 by CosmicLogos, on Flickr
What should it be?
