Note that those are not using the same design as these ML fans, they are more for bling than performance![]()
Ah that's a bit unfortunate... they won't be anything special in the performance department then. Seems they missed a trick not including RGB on the ML range and limiting to fixed red, white or blue, but perhaps they figured they were expensive enough already.
