- 2 Dec 2006
The clocks manufacturer state are the hard BIOS boost clock, as such the card never drops below this and will achieve this typically even at 80c. The moment they are below 80c they run above the stated clocks.
So it is not impossible for say a completely stock Strix 1080 out the box if it has a good ASIC to boost over 1900MHz or even 2000MHz, so pretty much the boost clocks of the OC part.
The difference is the OC parts due to having its hard boost clock set much higher means at lower temperatures it could be hitting 2.1GHz plus and this is the issue the amount of Pascal GPU that can do 1900MHz plus at 80c are few and far between, yield is very low.
Of course in real world use most of these after market cards with larger coolers run around 65c so run far faster than advertised clock speeds.![]()
Thank you for explaining
