The Pascal GTX 1070 Owners Thread
Caporegime
20 May 2007
Surrey
This is why I decided to uninstall it after a few days and just install Afterburner to make use of proper fan curve control and having the OSD.
Seems bizarre why Zotac didnt just have it like that in the bios (ie 0% then 33% onwards from 60 degrees). Seems like the much better way to do it.
Still, i reckon in winter, the heatsink is so big it might not even need the fans and will just need passive cooling :p
5 Jul 2005
Brighton
Can you take a picture of it inside the case? The 980Ti had the tackiest writing on it.
Not mine, just fixed the image link for him.
That's the back though if that's what you meant.
You might be right, same for my Palit one. Quite a big OC, in a case designed to be quiet and a room that's 28c+ it's only hit 68c @ 40% fan speed.
8 Sep 2012
Here's the MSI inside my case:
[/url]screen shot windows 7[/IMG]
Sorry for the abysmal picture quality, my phone doesn't do too well in dimly lit environments.
That damn case won't allow for any sort of neat cable management:mad:
8 Sep 2012
Can you turn the white led off the MSI logo?
The LEDs can be controlled via the MSI Gaming app but I don't know whether you can turn off the MSI logo independently of the rest. I'd bet you can but I've yet to try the app, didn't have too much time today to give the card a proper spin.
EDIT: I don't know whether it's too visible in the picture but those red accents on the cooler light up as well;p It looks a bit gaudy to be honest;p
30 Mar 2010
Under The Stairs!
@TNA, in regards to the fan ramping, does yours do it all the time, even from boot without running any games?
Mines doesn't do it until gaming, then when finished it keeps doing it for a few mins until temps drop then it's back down and stays idle.
Caporegime
20 May 2007
Surrey
Yes mine does the same. At idle/desktop the fans are stopped. When approaching 60 they rev on and off a bit then stay on. Then when cooling down they rev a bit then stop. It is a bit of a stupid design but can be remedied quite easily by the looks of it.
As TNA pointed out though, you can get round it by just setting a custom fan curve so that 0-30% ( the "revving" bit) is cut out so it just goes straight to where they are on constantly (around 30-35%) at a given temperature.
TNA
TNA
Caporegime
13 Mar 2008
Greater London
No, it only does it when the temperature is hit about 58c until mid 60's I think. Then it does it again when trying to cool down.
Very stupid design.
Thanks, the ramp up doesn't really bother me, as long as it's off in general it's not a biggie, I only run a NH-D15 on silent with no case fans in a Primo and not too intrusive for a few mins.:)
I thought the same, give it time, you only just got the card :)
It will start to get annoying in a few days time. You will realise once you play certain games, it will be stuck in revving mode the whole time as that particular game may only push the card to say 60c.
Caporegime
20 May 2007
Surrey
It is a stupid and bizarre problem. Why would they design it like this? The custom fan curve fix works fine but it would be better if the fans just slowly increased from zero.
It doesn't really bother me as I got it for a great price and 2ghz+out of the box and 60 degrees running temps on air can't be sniffed at.
TNA
TNA
Caporegime
13 Mar 2008
Greater London
+1
Not bothered. Though would be nice if they released a bios that fixes it. Even if fans cannot run slower than sub 30%, they should just release a BIOS that has a fan curve that kicks in at 33% when it reaches 50c/60c or something. That way no need for afterburner to run in the background.
27 Feb 2015
For the curious, since there is no pascal bios editor yet I took a punt and asked palit if they would make a increased TDP bios, they said they will get back to me in 7 working days with it, so this will be interesting. I asked for 30 extra watts.
11 Aug 2005
Cambridge
+1
Kicking in is probably part of the problem. If you have a simple:
if (temp > x <= y) { fanspeed = Z }
then you'll always have an issue when the boundaries are crossed.
The fix is really easy, you just add a dampening function, especially to the fan drop stage. At the simplest you can say 'never drop fan speed until at least 10 seconds since the last change', or you can get more complex and average out temperatures or use hard and soft boundaries during your dampening period.
Curves on a graph don't address any of that - they just allow more boundary points. Anyone know of any cards that let you script fan control?
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and TROH updated.:)
The Roll of Honour.
Date 15/07/2016, Make KFA2 HOF, Solidair, Link
Date 18/07/2016, Make MSI Gaming X, Amatsubu, Link
Date 18/07/2016, Make Zotac AMP Extreme Edition, Jono8, Link
Date 16/07/2016, Make Palit GameRock Edition, Raikiri, Link
Date 16/07/2016, Make Gigabyte G1 Gaming, foster grant, Link
Date 16/07/2016, Make Zotac AMP Extreme Edition, tommybhoy, Link
Date 16/07/2016, Make Zotac AMP Extreme Edition, TNA, Link
Date 15/07/2016, Make KFA2 EXOC, Darren_uk, Link
Date 14/07/2016, Make MSI Gaming X, Troezar, Link
Date 14/07/2016, Make Zotac AMP Edition, Mario, Link
Date 13/07/2016, Make Zotac AMP Extreme Edition, MarkeR, Link
Date 13/07/2016, Make Gigabyte G1 Gaming, foster grant, Link
Date 10/07/2016, Make Gigabyte Windforce 2x, wellibob, Link
Date 10/07/2016, Make Gainward Phoenix Golden Sample, roddypoddy, Link
Date 08/07/2016, Make Palit GameRock Premier Edition, chrcoluk, Link
Date 08/07/2016, Make Palit GameRock Premier Edition, JTrickle, Link
Date 08/07/2016, Make Zotac AMP Edition, gtw1212, Link
Date 07/07/2016, Make MSI Gaming X, magicoi, Link
Date 06/07/2016, Make MSI Aero OC Edition, Amatyr, Link
Date 06/07/2016, Make MSI Gaming X, divinebeetle, Link
Date 04/07/2016, Make MSI Gaming X, i_am_jon, Link
Date 04/07/2016, Make Palit GameRock Premier Edition, Phil87, Link
Date 03/07/2016, Make MSI Gaming X, V_R, Link
Date 03/07/2016, Make Palit GameRock Premier Edition, foxyfaefife, Link
Date 03/07/2016, Make MSI Armor OC Edition, chris-82, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, razorpakk, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, styuR, Link
Date 02/07/2016, Make MSI Armor OC Edition, Shawreyboy, Link
Date 02/07/2016, Make Gigabyte G1 Gaming, Gripen90, Link
Date 01/07/2016, Make Gainward Phoenix Golden Sample, shrek2, Link
Date 01/07/2016, Make NVidia Founders Edition, BornEvil, Link
Date 30/06/2016, Make Gainward Phoenix Golden Sample, thefogo, Link
Date 30/06/2016, Make MSI Gaming X, Carta, Link
Date 29/06/2016, Make Zotac AMP Edition, Charlatan, Link
Date 29/06/2016, Make MSI Gaming X, Daaaveee, Link
Date 29/06/2016, Make MSI Gaming X, Aretak, Link
Date 29/06/2016, Make Inno3D iChiLL X3 Edition, leerogers00, Link
Date 28/06/2016, Make MSI Gaming X, DougF1, Link
Date 28/06/2016, Make MSI Armor OC Edition, markoboyo11, Link
Date 27/06/2016, Make Zotac AMP Edition, Mangochutney, Link
Date 25/06/2016, Make MSI Armor OC Edition, BornEvil, Link
Date 23/06/2016, Make MSI Aero OC Edition, McGraw, Link
Date 22/06/2016, Make MSI Armor OC Edition, smithy83, Link
Date 21/06/2016, Make MSI Armor OC Edition, Phixsator, Link
Date 20/06/2016, Make Palit Founders Edition, Paul_cz, Link
Date 20/06/2016, Make NVidia Founders Edition, Dave2150, Link
Date 20/06/2016, Make MSI Gaming X, AthlonXP1800, Link
Date 20/06/2016, Make Gigabyte G1 Gaming, w00dy85, Link
Date 19/06/2016, Make MSI Gaming X, kully1972, Link
Date 18/06/2016, Make MSI Gaming X, AliGoz, Link
Date 17/06/2016, Make MSI Gaming X, philo-sofa, Link
Date 16/06/2016, Make Palit Founders Edition, Biffa, Link
Date 16/06/2016, Make EVGA Founders Edition, Daaaveee, Link
Date 14/06/2016, Make EVGA Founders Edition, mankycrack, Link
Date 13/06/2016, Make NVidia Founders Edition, !bluetonic!, Link
Date 12/06/2016, Make MSI Founders Edition, yoyo59, Link
Date 11/06/2016, Make MSI Founders Edition, JamesM, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1070.​
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Interesting.
Don't know of any software or cards that let you script fan control however.
18 Dec 2008
Well after buying 2 second hand 980Ti's and experiencing coil whine with both, I've sent them back and cut my losses...and I've ordered an MSI GTX 1070 Gaming X - should arrive in the next 2 days! (not from ocuk sadly, their gouging stretches loyalty beyond breaking point).
Upgrading from SLI 970s (both MSI Gaming Xs as well), so hoping for zero coil whine, low temps and quiet fans just like my 970s. Hoping I won't be disappointed!
out of interest, what values are people getting out of their 1070s in Afterburner, in terms of core and memory clocks? My 970s both ran solidly at +150 core, and +300 on memory.
