Can't deny that you make a fair point. It's just I have a 1440p monitor and sorta wanted my next card to last me 4-5 years and max out star citizen. I'm coming from a 570 GTX, so I tend to not upgrade very often.
Currently on a 570 GTX. Been a long time since I upgraded. I'm currently stuck in the witcher 2, Dark souls 3 (Which I play at 720p) and FO4 where I cannot continue past a laggy area.
I nearly beat that armour boss thing in DS3 on my first try at 15 fps. Kinda rage quit after that one.
Needless to say, I haven't had much of a gaming life in the past year or so and it's even worse that I used to game at 1440p. The 1080 was meant to blow my mind away.
I bought the OC version however putting the card in OC mode which sets the boost clock to 1936 MHz, as advertised, results in a crash.
Every card boosts over its set boost clock due to GPU Boost but because it boosts over the stated clocks OCUK say they cannot support it.
I am now left with a card that I cannot run at the stated 1936 MHz boost clock with OCUK trying to wash their hands of any responsibility.
Just a heads up for anyone looking at the OC version.
But that is right surely you turn off GPU Boost so that you have it in OC mode which keeps it stable at 1936Mhz? I don't know as I just by a base card and OC mine the old fashioned way rather than using another profile from manufacture.
But it is guaranteed to run at 1936Mhz and nothing more so I would say that unless it is not running at least those figures then OcUK would be fine. Just PM Gibbo to confirm and explain and go from there.
OcUK will support you if they can.
It sounds like all he is doing is enabling the OC mode in the asus software and nothing else, but it isnt stable.
I have a suspicion that ASUS are having trouble getting the STRIX OC to stay stable at the quoted levels which is why so few are making it out in to the world. It could be the reason for this poll. You can get the STRIX gamer card but you wont reach the OC levels of the STRIX OC because the chips are so rare.
gray, you have a chip in the card that isnt good enough to handle the specified over clocking levels that ASUS have clearly stated. For this reason it should be returned and you should be offered a full refund or replacement.
I say 'should' because i believe it is still upto the seller to accept this or not. You are best off contacting the seller privately instead of within a forum.
If i receive my STRIX and it does not reach the clocks as stated and stay there stable in the OC mode then it will also be returned. I paid the extra to reach these clocks guaranteed and im sure you did too.
It might be worth checking your PSU as well...
Hi this is exactly what I am doing but OCUK don’t want to know.
When I reiterated the point I wasn’t trying to overclock the card past the 1936 MHz boost clock I got this response.
http://i1262.photobucket.com/albums/ii602/Zheith/ocuk_zpsh6txqig5.jpg
I’ve now had to order another 1080 from a competitor and I can’t see any option but to forward the case to my solicitor as I’ve contacted custom support multiple times and gotten nowhere![]()
Maybe someone at OCUK would like to comment here? If you send out any GPU that states a certain OC level guaranteed and that same GPU does not reach that OC value what is your policy?
I dont really expect you to answer here but i dont want to be in the same boat as this guy when i get my card.......
