Having trouble with my wife's new redmi note 3 pro. It works perfectly using the nano sim card in the nan card slot.
But want to use a SD card in it too, so put the sim in an adaptor to move it over to the other sim card slot, wth the SD card in place. It keeps losing signal constantly coming and going sometimes a couple of seconds apart, sometime up to 10-15 seconds. But it also doesn't seem to recognise the SD card is in there.
My phone is set up exactly the same and is working perfectly. Both phones are on the same software version too.
Anyone got any ideas?
That's a bit odd, sounds like something is not seated right, might be worth swapping the sim trays see if you get the same result. I would also not use an adapter either if it get's stuck your screwed basically.
Try MIUI 8 global beta Darryl, the battery life is even better and it uses a little less memory.
Go into your bootloader menu, wipe the device +dalvik and cache and then return to your backup?
Best place to get the redmi note 3 pro from currently? Going to grab one for myself today i think, the smart ultra 6 needs a holiday!
Also, the other half needs a phone with similar spec/price as the note 3 pro, but with a 5" screen rather than 5.5"...recommendations?
....and runs 4g on O2.![]()
Top one on Ali express for the note 3.
