Yeah, they should definitely have redundancy at their primary sites, but it's more common than you think for ISPs not to have redundancy at that level..
id be amazed if the london datacenters did not have power redundancy.
Will be interesting to read the response to that one - so much for redundancy...
Disconnects as in…? You shouldn't get loss of sync as a result of this, you could potentially see issues with PPP sessions though.
If you are physically dropping your link then it's unrelated to Telehouse problems.
BT Infinity dropping about 6 times a day since the "fault". Harrow, NW London.
Same here dude, drops around 5-10 times a day since the fault.
Connection has been solid for a while now, faults happened the other day and now it keeps dropping Tottenham, North London.
I'm back to a more solid connection, only dropping once a day now but I've lost 20mb in download speed. How about yourself mate?
I'm seriously thinking about cancelling at this point.
The cabinet probably has some damaged kit due to the temperatures we saw last week. It happening at the same time as power issues in two London data centres is a coincidence, though potentially with the same root cause.
Are the BT DNS servers still pants for others compared to Google's4.4.4.4/ 8.8.8.8?
You'll get it fixed in time for a thunderstorm to fry it![]()
