Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Technically 4 starts...as for how cold it was, how cold does it get after 30 mins, an hour and then another hour.
A good callJacked each corner up and took each wheel off, all seems to be moving as it should so I guess that eliminates a binding caliper - that's something at least.
I'm quite tempted to just replace the front discs/pads if they look in any way knackered when I take them off and then garage it if that doesn't sort the juddering. Haven't got a pad wear warning in dash yet and they look like they have a decent bit of meat left in them but who knows what the inside of the disc and inside pads look like.
It seems to be quite a common thing on E90s and the vast majority of the time it seems it's the front discs/pads that are the problem. I'm just not sure how it could have happened as I always put the handbrake on after slowing to a stop etc. I guess I'll see how it goes tomorrow.
[TW]Fox;29837772 said:They are not 'cold starts'.
But not a "single" journey either.
But after sitting for an hour in the heat we have had recently the coolant temperature won't have dropped much below the threshold for which any warm up enrichments are applied and because of the temperature things remain there is very little in the way of enrichment lasting for very little time
Put new wheels on (left new / old on right), got ham fisted and scraped a bit where the wheel nut goes!
https://s32.postimg.org/jbs8lkxqt/13708163_1139242872763223_381899185972329554_o.jpg[img][/url][url=https://postimage.org/][url]
Managed to do this because I didn't have any long sockets in 19mm handy so had to use a short... Too short.
[url=https://postimg.org/image/l27it4p41/][img]https://s32.postimg.org/qqdtk0tgl/13710724_1139242386096605_1846982347804691282_o.jpg[img][url][url=https://postimage.org/][url][/QUOTE]
Saw a white FN2 with those wheels earlier on, thought it might have been you at first, but I doubt it was, unless you were in Sussex. :p
Applied the 2.5th(!) and final coat of the Renovo Ultraproofer.
A single coat is said to last up to 12 months. So I think I'm sorted for up to 24.
Went to collect my "fixed" car, but got half way home, still running like a dog and fault codes. Will give one more chance and if not will be trying to get my money back![]()
It's Fox. If he's not being pedantic there's something wrong with the world....![]()
Saw a white FN2 with those wheels earlier on, thought it might have been you at first, but I doubt it was, unless you were in Sussex.![]()
