Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
Humbug, on your game screenshots what are you using to give the onscreen stats in the top left corner or is that actually part of your game?
Didn't know Afterburner gave you cpu load and temps as well. Been using EVGA Precision and that only gives you gpu data.
The real question with Zen is will we see apt motherboards? There's not much point going with Zen if the motherboard isn't good for what you want, whether it's 24/7 operation, looks or overclocking ability.
Shipping with limited quantities indicates that it's a very good chip, as good or better than they expected. Otherwise, they would build an inventory before selling to capitalise on hype. I'm also betting that this is a performance at a price that customers will hold off upgrading for, even if they can't get one for a month or so.
I'm expecting this to be good.
Don't do it to yourself.
It's not at the Skylake level which AMD claimed months ago.
Now first off AMD haven't claimed it was at Skylake level, second, a gpu benchmark and a single benchmark at that isn't a way to claim where performance is at and lastly this isn't shipping clocks. What AMD claimed was 40% faster than.. something, people argue over Bulldozer, Excavator, etc. This was 38% faster and if the retail chips came at say 3.6Ghz boost speed it would be somewhere around 55% faster than Bulldozer, which would probably be around 40% faster than Excavator... which is actually what AMD always claimed.
Second, http://www.anandtech.com/show/9483/intel-skylake-review-6700k-6600k-ddr4-ddr3-ipc-6th-generation/15
Oh wait, look how much massively faster the 6700k is in gaming over a 4770k.... in some games it's slower than an Ivy bridge let alone the lower clocked Haswell than the one from the Aots benchmarks.
Third
http://semiaccurate.com/2016/03/01/investigating-directx-12-cpu-scaling/aots-dx12-cpu-scaling-2/
As you can see, over 6 threads reduced performance(well cores, they didn't do 3 cores + HT) so can't see if that would be better or worse than 6 real cores. Assuming that because it's a real 8 core THIS benchmark should be much faster if it has more cores is simply illogical, it's not a CPU benchmark it's a game and wasn't designed with a purely 8 core 16 thread CPU in mind.
The ES chip has below shipping clock speeds, so using the current performance as an idea of final performance couldn't be more flawed. That it's not faster than a i7 Haswell you're using as proof it's no where near Skylake, despite the reality being that Skylake is often no faster at all in gaming benchmarks than Haswell. Games aren't perfect CPU benchmarks. It's a monumental leap from Bulldozer and that is what Zen claimed to be. With higher clock speeds the gap to Bulldozer only increases which means AMD is dramatically more competitive than they were before. Going from lets say 40fps to 58fps compared to a more expensive Intel chip getting 65fps, is a massive improvement whether you choose to ignore it or not.
Good summary.
And also, in general, if it did turn out Zen gave ~10% less FPS in games than Intel, but offered 2 or 4 cores extra for the same money, I bet many people would take that trade. I certainly would.
If you compensate for the clock speed difference, Zen is faster than the rest in that benchmark figure you showed. It'll be a while before we know how well Zen clocks though. I have no idea what the hell it's testing though, does it include the IGPs or are they using a separate GPU?http://wccftech.com/amd-zen-es-benchmarks/
First Zen ES Ashes of the Singularity benchmark leaked.
Zen ES has 2.8GHz base clock and 3.2GHz turbo clock but the performance is slower than Haswell 4790 CPU, it not at skylake level AMD claimed months ago.
Zen ES are seemed underwhelmed for 8C/16T, if the final retail are similar or slight improved peformance at higher base and turbo clock then guess I will wait for Kaby Lake.
