970 3.5GB 'Ramgate' - NVIDIA ordered to pay $30 to each owner
Caporegime
18 Oct 2002
Ireland
You know what im getting at, the way its described makes you think you get the combined power of both cards using an 8gig bank of ram rather than 2 gpus using 2 lots of 4gigs. Im sure im not the first person who thought it looks a bit dodgey.
As for nvidia advertising the same way if you look on their spec sheets on their web sites the nvidia one clearly states 2gig per GPU for their 690 and the AMD states 6gb gddr5 for their 7990.
http://www.geforce.co.uk/hardware/desktop-gpus/geforce-gtx-690/specifications
http://www.amd.com/en-us/products/graphics/desktop/7000/7990
Anyway im sure you knew what i meant but was just trying to have a dig.
Makes little difference what on the spec sheets as the boxes advertise the same way. Example
https://www.google.co.uk/search?q=g...=isch&q=gtx+295+retail+&imgrc=YJD3jmqnJqTaHM:
Suspended
30 Mar 2010
Under The Stairs!
I guess we will have to agree to disagree.
The reviews always state you get 2+2/3+3 etc Blud, it's not the same as stating 4Gb instead of Nv should have fessed up instead of omitting the fact it's got 3.5Gb TurboNutter/500Mb SnailPace and missing rops.:p
Just so that guy doesn't jump down my throat-my 970 was a cracker-next one stayed intact and was brilliant.:D
bru
bru
21 Oct 2002
kent
I really don't understand how anyone can argue against it having 4GB of ram, especially as the normal argument is, it has 3.5 GB or normal ram and 500MB of slower ram. Guess what 3.5GB + 500MB = 4GB.
Ok argue about the memory bandwidth, the bus width, The ROP count, The level 2 cache, being an NVidia card, not liking the colour green, but it does have 4GB's of ram. :)
6 Jan 2013
Rollergirl
It's not the numbers, it's the visual result when the cards enter that dreaded 0.5GB zone. A slideshow is a slideshow regardless of semantics.
Suspended
30 Mar 2010
Under The Stairs!
I wasn't getting the use of the full 4Gb at one point bru, they capped it after the **** storm.
When I went 970 after the dirty scandal:p, I found out that mine would sit just over 3.7Gb usage no matter what, but then a fair few months later it did start to use the whole 4Gb, whatever workaround they used in the driver idk, but they did get there eventually.
Now before I'm told 'bs mines always used the 4Gb', gregsters 970 review exhibits the same as mines did-his never went over ~3.73Gb@1440p either, so it's not as if my setup was an isolated case, if yours didn't great but that could also explain why some didn't get anything untoward and that's why they are so vocal about it too.
And I suppose that's what Nv get in the end, (never mind what the red team think of them) the perception of some of their own customers are now seeing them as lying *******s.:)
14 Jul 2004
This is a slap to the gaming media community as well as Nvidia. They have a particular role in calling out anti consumer behaviour, which is rife in PC hardware, particularly in the CPU and GPU spaces. The media has failed to do that, and in most cases sides to far with the vendors.
2 Oct 2012
Probably BS as i was told as it worked fine from the start and there was no driver etc that fixed anything :rolleyes: lol
I should probably move along because apparently never was an issue. Means nVidia did no wrong. Don't claim $30 dollars and don't pass go.
gotta admit 970 was and still is a great card. shame about how it started off as it tainted it. Even more a shame nvidia cut corners with the card. might be why they sold it as cheap as they did.
17 Aug 2003
Woburn Sand Dunes
R7slayer stop making stuff up, it's pathetic. The card is compromised, nobody said it was without fault. Nobody said nVidia are perfect. Nobody said there wasn't a driver that fixed everything, i said i can't remember there being one. Seems nobody else can either.
I told you I was here if you wanted to debate amicably, like an adult. Thats clearly a no, then.
Trying to give us 4gb of ram instead of 3.5 wasn't cutting corners, it was an attempt to give the card more resources. In retrospect they shoulndnt have bothered and instead gone for a simpler 3.5gb card but we all know those specs would have put the card at a disadvantage next to the 290x. Probably why nVidia thought they had to try. Most of this I've mentioned in a previous post though, and you ignored that so..
Tommybhoy, why did 3.7gb become a thing anyway? The issue was passing 3.5gb and it turning in to a slide show, not 3.7. if youre at 3.7gb usage then you are at least already using the 500mb partition for caching, if not actively accessing it.
Nobody said they had 4gb use in every game, so why would you think somebody's going to jump down your throat? I don't get 4gb usage in every game now.
Permabanned
12 Sep 2013
Knowhere
And for the record, ive been saying the cards will run out of grunt before they run out of ram since day dot. And where are we now? I cant run games at 60fps without turning detail down. I have most of the fancy stuff turned off, for example, in The Division and i still cant maintain 60fps. Not enough grunt, not a ram issue (2560x1080). RAM is/was an issue for SLi users but then as i have said all along they we're more than entitled to return the cards fora refund.
This isn't the only way for the memory limit of a card to be exceeded and I've been saying that since year dot as you put it, The difference is I got laughed at for saying I was selling my 780 Classified as it did not have enough ram a few years back, The reason it didn't was because I used a lot of textures mods and today games are starting to do the same and use high quality texture files that use a lot more memory,
Memory usage is not tied to just performance hogging settings such as AA, Nowadays there's quire a few games that use the memory up through the size of the texture files and the number of games is going up all the time.
I own a games that I can run beyond 60 fps that stutter like a pig because the 4gb's of memory on my card has been exceeded and more games are being added to the list all the time.
Suspended
30 Mar 2010
Under The Stairs!
I never said it was a slideshow if you could read what I said objectively I think it would be easier to interpret, but I'll try and simplify what I said one last time:
Bru said there's always been 4Gb, in a direct response to that comment I said what I saw was that it never always had 4Gb available.
In known vram hungry games it was [email protected] for the game/up to 225mb for driver/os for quite some time, then all of a sudden the remaining slow ram was made available in the same vram hungry titles, the card started using all of it's available ram=you never got the whole 4Gb to use for some time.
