*** The Division Thread 2.0 ***
8 man squads don't work.
I have had more success with 4 man groups ffs.
No more 8 man for me.
Same, will be sticking with four rather than trying to get large groups together.
If one group goes rouge or both groups do and your trying to kill randoms then it's extremely hard to find who to point your gun at. By the time you figure out which is the random agent they may have killed you.
And apologies to Jedi and Tek for trying to kill you, never knew who it was until we started shooting :eek:
Yeah I have a few firearms mods on the build, trying to bump the DPS, I have lots of lvl 32 Stamina mods, with Skill power I can put in, but obvs my DPS will take a hit.
or do you mean, Roll higher Stamina on the gear set piece itself ?
Can change to Savage Gloves, but would miss out on the 50% EDR from 2 piece FM
All ends up, its just not doable without better gear :(
Just a tip, do not attempt to boost your dps by firearms, it is the worse base stat across all three. As soon as you hiyt 2825 (or 2260 in the case of rec support) you should be stacking something else.
Also, I would recommend spending more time in DN/FL before starting to optimize your setup, since the current meta is more about using specific gearsets for specific purposes and less about your individual stat.
And one more thing, I can tell you from personal experience that FM is not manadatory anymore in the dz as long as you have 450+ toughness and does not let chain reaction proc. (It also helps to have EDR on chest and kneepads but that's best in slot)
thanks DeFi....yes FL & DN must be my destinations for gear...I just need a good community based crew to help .......if only there was a community that regularly played and could help....hmmmm lol :D;)
No worries man, was a good bit of fun. Mario did actually kill me one time though, that was funny!!! :D
And yes Gamble, I agree a well-equipped 4-man squad would be far more effective for getting the PvP.....but not as much of a giggle :p
You dun really need a crew for any incursions as long as the team formation is on point, heroic UG and dz are the ones that needs a proper team but those really are underwhelming atm
Yep, that was a moment of panic. You'd gone afk for a moment as well and then the next thing I know I'm surrounded by rogues. Had flashbacks to an earlier extraction:D
Is there some sort of uber build that I'm not aware of? I was just in the subway section of dz6 when a single rogue shot and killed me from behind. 500k toughness and downed with ease. I re-spawned, grabbed my brutal, deadly, self preserved mp7 and tracked him down. He was stood with his back to me so I fired a full magazine into his head at almost point-blank range. His health didn't drop even slightly.
Was very hard to to see who is who,was chaos..besides i was with my alt,who didnt had good gear on,so was using M1A to snipe everything on its sight :D
I need to work on dedicated PvP centry :( All my builds are oriented PvE
I have heard of missions not resseting themselves but i have the oppposite the last 2 days i complete the 3 daily missions and they are ticked after each is completed but then disappear!
Anyone else had this bug/issue?
Hacks creeping back in maybe...??
