Interesting F-Type fact: the 6 cylinder model shares the same block and same length crank shaft as the 8 cylinder model, but has the pistons removed and the cylinders blanked.
Not an ideal solution at all for a sports car IMO.
I noticed its a diesel but still wouldn't complain if I had one!
From an engineering POV is that even possible?
The load distribution would surely be impossible to balance ?
Surely it would be cheaper to have a different engine![]()
NickXX is correct. The v6 is the v8 minus two cylinders, minor changes to the block and with shorter cylinder heads. The crank is also the same length as the v8. The project was really started to give the engineers something to do and then people were surprised when the engine was released to production.
Surely that engine will be prone to end float?
Why?
Does that mean if you were that way inclined, you could buy a v6 then upgrade it to a v8?
Because the crank has 25% of its length without any forces (other than rotational) acting on it. From further reading it seems they added a balance shaft to compensate for this. What is the engines reputation RE high mileage examples?
	I really can't disagree with that!! It's truly beautiful and very much a car I would love to own...I'm also eyeing up the XKR
http://www.autotrader.co.uk/classified/advert/201604092795988
I was having a browse around auto trader last night. The nearly new XF-R's look incredible in white with the 'Black Pack'
Exhibit A Oh my lawd, stunning
http://www.autotrader.co.uk/classified/advert/201607045514788/usedcars
Just ran an insurance quote on that, it would cost the same to insure as my 4k Kia Sportage! Hilarious.
