Hi guys
I recently finished buildling my first PC. I am still very new to this and trying to learn as I go along.
To cut a long story short, I was trying to install Windows 7 Pro onto my hard drive, but windows was throwing up some errors to do with partitioning. I had used DiskPart to convert it to a GPT partition table. After a lot of faffing around and solving problems and dealing with new ones, all based around the installing of this copy of windows, I got there. The initial set up finished and windows booted up. However it was logged in for about 10 seconds before restarting, and then hanging on the Gigabyte splash screen.
Now whenever I turn it on it just hangs on that screen, I can not enter the BIOS or boot menu. Removing the drive solves this problem, so there's obviously an issue there.
I'm a little bit concerned that I may have messed the drive up and was thinking of mounting it in another machine and formatting it from inside windows to get it back to it's factory defaults. Or, more specifically, ready to host Windows 7 Pro. Can you guys lead me in the right direction?
Set up:
Many thanks!
Set up:
- Kingston 240GB SSDNow UV400 Drive
- Gigabyte X99-SLI
- Intel Core i7 5820K
- Kingston Predator 16GB (4x4GB) DDR4
- MSI GeForce GTX 960
Many thanks!
