Improved overclocking in theory. Plus the fancier models shipping at higher frequencies and with dual fan coolers are going to consume a few more watts, which is an issue when margins are so tight. There were some 750 Tis with a 6-pin as well, despite most being slot-powered.How come some of them need a 6-pin and some don't ?
So with DX12 and Vulkan being adopted more 4GB is actually a benefit on the RX 460 and I'd say 55fps is perfectly playable.![]()
470 up to 100% faster at £30 extra cost, who is buying a 4gb 460?
https://www.overclockers.co.uk/sapp...s-graphics-card-with-backplate-gx-37g-sp.html
I was in a similar situation, using an old 1440x900 monitor until 2014 when I got back into PC gaming and built my first system since 2009. A "mere" 1080p/60fps might seem quaint to a lot of people here these days, but moving from a ratty 19" 900p TN screen to a 24" 1080p IPS one was amazing at the time.I would imagine some people might still be on monitors at resolutions lower than 1080p,which would mean the 460 would be a good card for them.
I had my philips 1650 by 1050 monitor for about 8 years,only upgraded to 1080p in 2013.
Just waiting for graphics cards to catch up now before moving to 4K. Probably be a couple of years before Titan XP+ performance is available at a reasonable price point.
Pointless and stupid argument!
Where does it stop? £30 more and you can buy a 4G RX 480, a further £30 more and you can buy a 6G 1060. At what point does more stop, a budget is a budget and for some people an extra £30 is not always so easily possible and many of our customers just want the best they can get for a fixed price point.
you stop when eventually you get considerably less increase in performance for that extra £30-£40 but for an extra £50 ish for a good 460 to a good 470 you're getting around double the performance give or take. the 460 isn't really great bang for buck.
Comparison against a apu. Might aswell compare it against a marmite sandwich in a gaming senerio to show its better !
Bit-techs review showed it as slower than a 950.
Edit: Though there card has no power connector, and looks to be power limited.
^ this.
Fingers in ears time, a budget is exactly that, if you worked in retail you'd realise ~95% of the time they won't go over budget because they can't afford to.
You won't get 1080p/60FPS from a 7850/ RX 460. Believe me, I had a 7850 until last year or so.
You might get 40 FPS on the absolute lowest settings. And that's your lot.
Honestly, I would not buy the 460 if you're looking to game at 1080p. It seems to be a card for streaming Minecraft, for HTPC, etc.
That said, the 7850 did well in older games like Skyrim. It managed to look pretty and played at decent FPS. But Skyrim is like a 2011 game (wow, time flies!).
A 460 to play modern games at 1080p will be a waste of money.
Budgets aren't always set in stone tho.
If you could have a car with no brakes for £500, or a car with working brakes for £750, but you only - at this time - had £500, what you going to do?
^ this.
