980 Ti vs 1080 - WHAT???
1 Nov 2013
I bought a 1080 today and compared it against my old 980 Ti.
Dissapointed!?
Memory clock on 1080 1251 stoc? hmmm
somethings wrong ?
7 Aug 2012
That is an above average overclock on 980Ti vs a fairly average oc on 1080 I would say. That said, I do understand that it isn't a large jump in performance.
But what you have to understand is that the 1080 isn't a huge leap in performance over the 980Ti and the Ti eats even further in to that with a larger headroom as far as overclocks are concerned.
I can't compare Firestrike on my 1080 as not installed at minute and stuck on **** poor internet for next couple weeks, but sure someone will be able to compare to ensure scores are in the ballpark.
30 Mar 2010
Under The Stairs!
1080 was only better looking comparing stock v stock with the 980Ti apart from certain titles where it was a good bit faster.
Flat out 980Ti v stock 1080(asking as 3Dmark doesn't always register my 1070 oc speeds on my end and just displays stock settings)?
Give it some time I think, with new games coming, the 1080 will pull ahead and outperform the 980Ti further especially as Nv shifted Maxwell onto eol and clarified that meant no more architecture specific driver optimisation for Maxwell.
OP
1 Nov 2013
i've been overclocking it added +140 core (2076mhz) and +600 mem (5603)
Considering the graphics score only the 1080 OC is now 15% faster than the 980 Ti OC - to be fair the 980 Ti OC was a very good one! - Panic over.
Caporegime
20 Jan 2005
Co Durham
his physx score is always 3% or more less on his 1080 build so his combined wont be as good and hence his overall score.
Looking at just gfx scores he's now 15.6% faster. Still doesnt quite seem enough though.
Man of Honour
13 Oct 2006
I'm quite surprised how much faster the 1070 I have is compared to when I had a 980ti in the same system - in the few games I have a point of reference for the 980ti i.e. GTA V, Everybody's gone to the rapture, BF4 there is a jump between 30% and 50% - albeit OC v OC that would probably be less but as the 980ti wasn't mine it wasn't overclocked.
OP
1 Nov 2013
Remember my 980 Ti was HEAVILY overclocked which added +1000 to the graphics score vs a reference model. The reference 1080 is ~22% faster than a reference 980 Ti.
Caporegime
20 Jan 2005
Co Durham
And an overclcoked 1080 is approx 20% faster than an oc 980ti again.........
Not seen what hes getting his 1080 overclocked to. It needs to be 2050 to 2100 to match the 1500 of the 980ti though.
27 Jan 2009
Its running exactly as it should...
https://www.techpowerup.com/gpudb/2839/geforce-gtx-1080
GDDR5 uses two separate differential clocks (unlike its precursor DDR3 which uses only a single clock).
http://www.hwstation.net/img/news/allegati/Qimonda_GDDR5_whitepaper.pdf
The first clock is used for command and address operations. The second clock is for reads and writes. The second clock is twice the frequency of the first. Data on the IO bus is transferred on the rising and falling edge of the read/write clock.
The GTX 1080 has a memory transfer rate of 10 gigabits per second. Multiply this by the width of the memory bus which is 256 to get the bandwidth in gigabits per second, and divide it by 8 to get the bandwidth in gigabytes per second which is 320 gigabytes per second.
The 1251 Mhz is the command operations clock the read/write clock is double this speed and is 'quad pumped' with some trickery involving using the rising and falling cycles of the clock...
so 1251*2 = 2502 and quadrupled again gives you your 10 Ghz or so effective memory speed clock (with one bit being transferred on every clock cycle to give a 10 gigabit per second data transfer rate)
