Can anyone help with upgrading please?
17 Mar 2013
Hi guys.
Had my PC over 3 years now and feel it's time for an upgrade. All i've done since I got this over 3 years ago is add an SSD. I want to be able to run the GTA V Redux mod when it comes out in a couple of weeks (
) - they've not released exact specs for it but I presume it'll take something fairly good.
Currently I have
Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz OC'd to 4.0GHz
8GB DDR3 Patriot RAM
Gigabyte Technology Z77-D3H motherboard
NVIDIA GeForce GTX 660 graphics
PSU and cooling is OK, I got really decent stuff when I first bought it and my PC is as cool as a cucumber all the time.
Any help would be amazing - thank you!
Your CPU should be fine for a while yet, GTA can be a little CPU intensive, but a new CPU will probably only net you a handful of FPS.
Might be worth going for 16gb ram, but far and away the best thing you could do is go for a new GPU. Theres a lot of good cards out at the moment to suit what ever budget you have in mind.
Really any of the new cards would be an improvement. What are you looking to spend and what resolution monitor are you using?
Thanks for the reply mate.
Using this monitor - https://www.amazon.co.uk/Asus-VG248QE-24-inch-LED-Monitor/dp/B00B19T7QC - which is superb, so it really gives me room for improvement I guess.
I don't particularly have a £ in mind, just something that is value for money, aside from GTA all I play is CSGO, which you could run off a potato and still get 300fps, which is why the 660 has been decent for me so far.
Would it be better for me just to go straight for a 970? Not sure if that'd be overkill, especially given the rest of my system.
looking at that I'd say the sweet spot will probably be around the RX480 or GTX 1060, both of those cards are really strong at 1080p and sit around about the £250 mark. They should both work well with your current set up :)
Of the 2 there's not a whole lot in it, the GTX 1060 is a little faster but also a little more expensive, and it looks like the RX480 might perform better with the newer APIs.
Bunches of different variations of each card on here. Mostly they're about the same, but the ones with aftermarket coolers tend to behave slightly better :p
GTX 970 prices haven't dropped as much as they should have since the 10 series cards were released and aren't good value for money anymore (at least not new).
As others have suggested, go for a 1060 or RX 480. This should give you the boost you need without needing to upgrade anything else in your system.
Not really much difference between them, I'd avoid the more expensive ones, and the small form or blower cooler versions unless you need it for a small case.
