- 11 Sep 2014
- Suffolk, England
Dumb question here, but is this a 19/13mm fitting or a 13/10mm fitting?
My advice to you, purchase a vernier.
Depends how the tube is meant to fit in it
Both very unhelpful answers. I have provided a rule against the fitting. All I'm asking is what the correct measurement is (ie, where to correctly measure to & from). Anyone else able to be more helpful?
I'm asking this question because in my build log it says they're 13/10 fittings, but when I measure the tube it's 19/13. So, I want to be sure of what I'm needing to get before I spend any money.
You're not really offering any motivation for people to want to help you...
A vernier is helpful.. If you bought the correct fittings then all you have to do is use a vernier to measure said fitting and tubing.Both very unhelpful answers. I have provided a rule against the fitting. All I'm asking is what the correct measurement is (ie, where to correctly measure to & from). Anyone else able to be more helpful?
Would have thought it was obvious just by looking at it what the fitting was? It's a Monsoon Compression fitting. The OD & ID of the soft tube used is 19/13. The tube slides over the silver barb & the gold compression ring....... compresses it.
