The Pascal GTX 1070 Owners Thread
2 Jul 2015
Odd that your temps are way lower than mine on the same card. I'm hitting 80c and it sticks there. Although it is being pushed a 100 percent when playing BF4 or The Witcher 3.
Mines seems to get to mid 70s at 100% still pretty quiet. Running at stock speeds which boosts to 1900 on the clock.
Having some other issues though. :(
27 Feb 2015
What I do think was great of palit is how they boosted the 2d clocks.
I notice people are posting 135mhz for 2d, but palit have my card set to 316. I used to run my 970 at 450 in 2d, as I think 135 doesnt cut it.
TNA
TNA
Caporegime
13 Mar 2008
Greater London
It's probably been mentioned already but this thread is HUGE! What is currently the quietest 1070 idle and under load? Thanks!
My guess would be Zotac AMP Extreme. Idle no fans. Load in low 60's Celsius and fan is low 30% so can just about hear it over case fans. Best cooler I have ever had.
Deleted member 2277
D
Deleted member 2277
The Palit Jetstreams are probably the quietest. Th zotac have an issue with the fans revving up and down so you either have to get used to it or create a custom profile which can mean running the fans at constant 40%. The Palit cards are super silent at no load as the fans do not kick in until the temp are 50 deg plus. Under load my fans are around the 30% mark and are inaudible over the case fans.
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
The Inno3D iChill Air Boss X3 1070 is also very quiet. The fans don't spin up at all when idling, only 30% below 50 degrees C and the most mine hit was 50% at 53 degrees C. Even at 50% it was more or less silent. Don't know what it's like at higher fan speeds as I could only get it up to 50% but I have it under water now.
27 Jan 2003
Chesterfield, UK
Does anyone really have a GPU that has zero coil whine under all circumstances? I've tried several different GPUs (2 x GTX 260, 4 x GTX 760 and a GTX 1070) with a variety of PSUs (Antec TruePower 750W, Corsair RM 750W, EVGA SuperNova G2 750W) and every combination has had coil whine at high framerates (> 300fps).
The GTX 1070 is by far the most I've paid for a GPU so I'm a bit disappointed mine still has coil whine. Is it even worth returning it for a replacement or will it just be a waste of time?
Most of the cards I have had did suffer from coil/inductor whine in certain situations. Benchmarking (3D Mark), Menus ... With VSynch on the problem usually went away. I had a GTX 580 that had zero coil whine and my 1070 is also silent. So yes you can get a card with zero coil whine.
Saying that it's probably still doing it but outside of your hearing range.
Some PSU's, Monitors, motherboards can also exhibit coil whine.
30 Jan 2007
PA, USA (Orig UK)
Today's adventure: Sitting on the desktop with Facebook and suddenly the screen corupts with lots of small multicolour squares. PC was frozen. Next bootup, fine.
I have de-clocked the memory slightly now. Been a fun time so far lol.
Man of Honour
13 Oct 2006
Get it replaced - my old laptop started doing that - first it would occasionally corrupt on start up then started crashing while playing videos and then would start freezing up earlier and earlier just on the desktop til it was dead as dead.
30 Jan 2007
PA, USA (Orig UK)
I flashed flashed the bios with the OC version. It made no difference, so i flashed the original non-OC back. Think that would make a difference in an RMA?
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and on TROH.:)
The Roll of Honour.
Date 15/08/2016, Make Zotac AMP Extreme Edition, Ian Jones, Link
Date 14/08/2016, Make EVGA FTW, The Dirts, Link
Date 14/08/2016, Make Inno3D iChill X3 Edition, pastymuncher, Link
Date 14/08/2016, Make Palit Super Jetstream, Dappo, Link
Date 13/08/2016, Make Gigabyte G1 Gaming, keasy, Link
Date 12/08/2016, Make Zotac AMP Extreme Edition, dunno, Link
Date 11/08/2016, Make KFA2 Reference, dampchimp, Link
Date 10/08/2016, Make Inno3D iChill X3 Edition, wam7, Link
Date 10/08/2016, Make Inno3D iChill X3 Edition, SlightOC, Link
Date 09/08/2016, Make Zotac AMP Edition, Kayjay333, Link
Date 07/08/2016, Make Inno3D iChill X3 Edition, RobinGopher, Link
Date 07/08/2016, Make Zotac AMP Edition, dunno, Link
Date 07/08/2016, Make Asus Strix, Scougar, Link
Date 03/08/2016, Make KFA2 Reference, pulsemyne, Link
Date 03/08/2016, Make EVGA FTW, Scramz, Link
Date 03/08/2016, Make Palit Dual Fan, melmac, Link
Date 01/08/2016, Make Zotac AMP Extreme Edition, Rom, Link
Date 30/07/2016, Make Inno3D Founders Edition, MOOGLEYS, Link
Date 30/07/2016, Make Palit Jetstream, Ogi, Link
Date 30/07/2016, Make Zotac AMP Extreme Edition, NinjaCool, Link
Date 29/07/2016, Make Palit Dual Fan, Bishie, Link
Date 29/07/2016, Make Palit Dual Fan, heatonpkmassive, Link
Date 28/07/2016, Make Zotac Founders Edition, _Jimlad_, Link
Date 27/07/2016, Make MSI Gaming X, Ex3cut3r, Link
Date 23/07/2016, Make EVGA FTW, Aretak, Link
Date 23/07/2016, Make Zotac AMP Extreme Edition, Defiant306, Link
Date 22/07/2016, Make Zotac AMP Extreme Edition, C6ckneyGeezer, Link
Date 22/07/2016, Make Zotac AMP Extreme Edition, Bickaxe, Link
Date 22/07/2016, Make KFA2 EXOC, MeatLoaf, Link
Date 22/07/2016, Make Palit Super Jetstream, Troop, Link
Date 22/07/2016, Make Asus Founders Edition, ah9098, Link
Date 22/07/2016, Make EVGA Founders Edition, Kaapstad, Link
Date 21/07/2016, Make EVGA FTW, clone, Link
Date 21/07/2016, Make MSI Gaming X, Gripen90, Link
Date 19/07/2016, Make Zotac AMP Extreme Edition, XeNoNF50, Link
Date 15/07/2016, Make KFA2 HOF, Solidair, Link
Date 18/07/2016, Make MSI Gaming X, Amatsubu, Link
Date 18/07/2016, Make Zotac AMP Extreme Edition, Jono8, Link
Date 16/07/2016, Make Palit GameRock Edition, Raikiri, Link
Date 16/07/2016, Make Gigabyte G1 Gaming, foster grant, Link
Date 16/07/2016, Make Zotac AMP Extreme Edition, tommybhoy, Link
Date 16/07/2016, Make Zotac AMP Extreme Edition, TNA, Link
Date 15/07/2016, Make KFA2 EXOC, Darren_uk, Link
Date 14/07/2016, Make MSI Gaming X, Troezar, Link
Date 14/07/2016, Make Zotac AMP Edition, Mario, Link
Date 13/07/2016, Make Zotac AMP Extreme Edition, MarkeR, Link
Date 13/07/2016, Make Gigabyte G1 Gaming, foster grant, Link
Date 10/07/2016, Make Gigabyte Windforce 2x, wellibob, Link
Date 10/07/2016, Make Gainward Phoenix Golden Sample, roddypoddy, Link
Date 08/07/2016, Make Palit GameRock Premier Edition, chrcoluk, Link
Date 08/07/2016, Make Palit GameRock Premier Edition, JTrickle, Link
Date 08/07/2016, Make Zotac AMP Edition, gtw1212, Link
Date 07/07/2016, Make MSI Gaming X, magicoi, Link
Date 06/07/2016, Make MSI Aero OC Edition, Amatyr, Link
Date 06/07/2016, Make MSI Gaming X, divinebeetle, Link
Date 04/07/2016, Make MSI Gaming X, i_am_jon, Link
Date 04/07/2016, Make Palit GameRock Premier Edition, Phil87, Link
Date 03/07/2016, Make MSI Gaming X, V_R, Link
Date 03/07/2016, Make Palit GameRock Premier Edition, foxyfaefife, Link
Date 03/07/2016, Make MSI Armor OC Edition, chris-82, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, razorpakk, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, styuR, Link
Date 02/07/2016, Make MSI Armor OC Edition, Shawreyboy, Link
Date 02/07/2016, Make Gigabyte G1 Gaming, Gripen90, Link
Date 01/07/2016, Make Gainward Phoenix Golden Sample, shrek2, Link
Date 01/07/2016, Make NVidia Founders Edition, BornEvil, Link
Date 30/06/2016, Make Gainward Phoenix Golden Sample, thefogo, Link
Date 30/06/2016, Make MSI Gaming X, Carta, Link
Date 29/06/2016, Make Zotac AMP Edition, Charlatan, Link
Date 29/06/2016, Make MSI Gaming X, Daaaveee, Link
Date 29/06/2016, Make MSI Gaming X, Aretak, Link
Date 29/06/2016, Make Inno3D iChiLL X3 Edition, leerogers00, Link
Date 28/06/2016, Make MSI Gaming X, DougF1, Link
Date 28/06/2016, Make MSI Armor OC Edition, markoboyo11, Link
Date 27/06/2016, Make Zotac AMP Edition, Mangochutney, Link
Date 25/06/2016, Make MSI Armor OC Edition, BornEvil, Link
Date 23/06/2016, Make MSI Aero OC Edition, McGraw, Link
Date 22/06/2016, Make MSI Armor OC Edition, smithy83, Link
Date 21/06/2016, Make MSI Armor OC Edition, Phixsator, Link
Date 20/06/2016, Make Palit Founders Edition, Paul_cz, Link
Date 20/06/2016, Make NVidia Founders Edition, Dave2150, Link
Date 20/06/2016, Make MSI Gaming X, AthlonXP1800, Link
Date 20/06/2016, Make Gigabyte G1 Gaming, w00dy85, Link
Date 19/06/2016, Make MSI Gaming X, kully1972, Link
Date 18/06/2016, Make MSI Gaming X, AliGoz, Link
Date 17/06/2016, Make MSI Gaming X, philo-sofa, Link
Date 16/06/2016, Make Palit Founders Edition, Biffa, Link
Date 16/06/2016, Make EVGA Founders Edition, Daaaveee, Link
Date 14/06/2016, Make EVGA Founders Edition, mankycrack, Link
Date 13/06/2016, Make NVidia Founders Edition, !bluetonic!, Link
Date 12/06/2016, Make MSI Founders Edition, yoyo59, Link
Date 11/06/2016, Make MSI Founders Edition, JamesM, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1070.​
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Not true. Revving is an issue yes, but that is an easy fix in afterburner with a custom profile. You can have it zero spin until 50C (or whatever you want to) and then have it go to 33% fan speed which is very low noise at about 1050rpm :D
Truth is from what I have seen probably 33% fan speed max is enough to keep card in 60's. Never seen the fan speed go above 40% with my fan curve ;)
So yeah, if you do not mind running afterburner in background, I am confident the Zotac AMP Extreme with it's beastly cooler is the quietest card of them all :)
25 Mar 2003
Scotland
I concur, my AMP Extreme is idling at 40 deg C (fan off) which is slighty odd as it was idling at 50 deg C yesterday... and motherboard temp is 33. Load temp rarely goes much over 63 with the fan on 33-40%. My Fan kicks in at 60 deg C.
