Having no stick control has just killed the game for me, like others have said. I just want the basic stick controls and not having that kills the immersion, and feel quite dissapointed a game like this has no built in support.
Just seems lazy to me.
Does anyone know if you have a +1 upgrade for a specific item attribute (weapon cooling, mining intensity etc), and you then get the +2 upgrade for that same attribute, can you get rid of the +1? I presume they don't stack and the higher level one replaces the lower level?
There is clearly something not right with this game... my FPS ranges from a maxed out steady 100FPS on my X34 to steady 60FPS... it rarely goes below that, but it seems to pick a frame rate and stick there for a while, then move on to another. I've never known a game do that before. I have a GTX 1080 and 5820K.![]()
They stack. You also get a bonus if you have similar upgrades positioned next to each other, you see a glow around the group of upgrades.
Started it up today and the juddering/stuttering is twice as bad as playing it yesterday :| pretty much makes it unplayable - can't even spin in a circle without it hitch for half a second to a second 3 times in 360 degrees.
EDIT: Just seen there is a NMS release driver 372.54 pushed out - gonna try that.
So in the same category they stack? i.e a mining intensity +1 and a mining intensity +2 equal more than just a +2 on its own? It's a bit (actually incredibly) stupid if it goes on position considering you can't move them once you've allotted it a space!!
So to clarify, for example, if you have the Beam Intensifier Theta, you get a bump by also having the lower level Sigma, as opposed to just have the Theta alone?
Yep, upgrades stack.
Anything of the same upgrade type (same icon) gets a bonus if it's adjacent to another upgrade of the same type.
Pay attention to those ship slot layouts![]()
Gamers Nexus thoughts on the issues....
Posted this earlier, might help. It's obviously not native support but might be worth a go if you want?
https://forums.overclockers.co.uk/showpost.php?p=29905904&postcount=2103
http://vid1367.photobucket.com/albu... Apologize. httpst.cov1BfN3cc_zpsw2wplcyk.mp4
Just gonna leave this here and run...
