I don't live in Lincoln, I live about 5 miles out in the middle of a field. A series of events led to it costing about £16,000 to reinstate the mains water supply. A well fitted for 7k was a much more viable option.
No, the well water is not the same as Lincolnshire tap water. This is the problem with most people, they make arrogant statements based on absolutely zero knowledge. The well is 46metres deep and takes water from a table which starts in Leicester. It runs through a shed load of everything on its way here. It isn't treated or filtered. It is perfectly safe to drink in the short term but if you would care to educate yourself on the long term consumption of excessive zinc, you will learn that it is not something you want to be doing. Linked to countless cases of brain and other organ issues, particularly in rural parts of America where they exclusively use domestic wells. You haven't tasted my water, I am not exaggerating when I say it taste like blood. The water has been independenly tested and zinc and iron are over the uk/eu specification.
