You have MSI Live Update installed, I'd only use it to check if any new drivers are available but then download manually from website. Most importantly, never use Live Update to update BIOS.
You could also uninstall the Killer Network software if you have that installed, and just install the driver on its own. "On-Board LAN Drivers - Killer Network Driver (driver only)" from the webpage for your motherboard. ke2400w10-x64 folder. Right-click on the "Setup Information" file in that folder and choose Install.
Try uninstalling the Corsair software too.
Just to trim unnecessary/sometimes problematic stuff in the hope there's some improvement.
I already removed that. I even reinstalled drivers in a good order, problem still persists.
Also, I need this Killer Network Driver, for some reason my internet cable won't get recognized without it.
I'll remove that software soon, test it out.
