What CPU for gaming?
hey guys,
i might be able to stretch my budget a bit, I'm not fussed about overclocking the CPU desperately. So how would a i5 6400 hold up as a long term solution?
RTJ
My basket at Overclockers UK:
Total: £253.68
(includes shipping: £8.70)
whether the 6300 is worth the extra 20 odd quid is up for debate but I'd just go with the 6100 if I was you
Sorry to be blunt but this is bad advice. That would be a downgrade. An i5 would be a marginally better sidegrade (for gaming only, it would be worse in some other scenarios). Only a newer i7 would be a worthwhile upgrade, imo.
OP - you should be able to take the 8350 up to 4.5GHz. Do that and see how much difference it actually makes first. I have an 8350 - they're reasonable chips, imo.
OP cant OC his 8350 not without spending £120 (990fx)for a new board, hes got a 780 chipset board no vrm cooling, no decent power delivery.
so the final choices OP has are
i3=avoid
15-6400=avoid
1150 based
i7-4790k over i5-4690k aim for sh (can reuse his old mem), i7 has high clock speed out of the box less scope for big performance gains via OC
1151
i7-6700k over i5-6600k
of course final choice will come down to budget, but the best win-win would be a SH i7-4790k
