They didn't mention if MSAA was on or off.
Previous article said with no MSAA it ran fine.
Yeah, this is the thing. All this info can be a bit misleading, as there is nothing stopping you from having a mixture of settings. It is not like there is just Ultra, Very High, High, Medium, Low presets and that is it. You can probably leave most stuff Ultra/Very High and just turn off a few settings like MSAA, Temporal Anti-Aliasing, Contact Hardening Shadows, Depth of Field, Motion Blur etc. Do that and your fps will likely double or more...
This is what I do in other games, turn off useless tat like Depth of Field, Motion Blur straight away. Then lower AA or turn it off. Boom, game is suddenly playable at 4K
So many people get confused about 4K thinking it is too hard to run. But if you think about it, you need less AA in 4K than you would do in 1440P. That right there is a fps boost. Recently I run Rise of the Tomb Raider on max settings but with no AA and turned off the useless tat mentioned above and guess what, it ran smoothly and looked gorgeous, same for Just Cause 3
