Unigine Heaven 4 benchmark
No snap shots can be used for the scoreboard.
The instructions in the OP definitely do work.:)
Thank you. I went looking for this screenshot folder (again) and it doesn't exist, so I added one in! Anyway it's working now! Thanks for everyone's help.
1425
I5 6600k @ 4.6 -- RX480 Nitro+ OC 8GB @1360/2200
I take it, the 4GB showing is a bug in heaven?
It would appear CPU has no effect in this benchmark as I must have used one of the weakest ones!
Any reasonable CPU runs fine with this bench.
If you are using a very fast graphics setup then CPU clockspeed will help to avoid a bottleneck.
