- 7 May 2016
Don't get a cx power supply, they are usually poor. I would avoid Corsair completely infact and get a Evga/Superflower.
) but is a great panel and a perfect match to the 1060 (I have both and have been very impressed!), it even has a green stripe which will match your colour scheme!Yeah for the PSU mate, Evga and Superflower make higher quality components for the PSU's. The top end Corsair Ax series are good but obviously wouldn't be in your price range and tbh I would choose Evga or Superflower if building for myself or anyone else. I do currently have an Ax series but I won't use Corsair again.
Danny specced this earlier and its spot on https://www.overclockers.co.uk/supe...0-plus-gold-power-supply-black-ca-003-sf.html
Monitor is out of stock (should be able to find elsewhere) but is a great panel and a perfect match to the 1060 (I have both and have been very impressed!), it even has a green stripe which will match your colour scheme!
My basket at Overclockers UK:
- 1 x Corsair Obsidian 750D Airflow Full Tower Case - Black (CC-9011078-WW)= £134.99
- 1 x Gigabyte GA-Z170 Sniper Intel Z170 (Socket 1151) DDR4 ATX Motherboard= £119.99
- 1 x Avexir Raiden Green Tesla 16GB (2x8GB) DDR4 PC4-21300C15 2666MHz Dual Channel Kit= £119.99
- 1 x Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)= £79.99
- 1 x AOC G2460PG 24" 1920x1080 TN G-Sync 144Hz 1ms Gaming Widescreen LED Monitor - Gunmetal= £299.99
- 1 x Samsung 250GB 750 EVO SSD 2.5" SATA 6Gbps Solid State Drive= £62.99
- 1 x Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)= £42.95
- 1 x Mionix ZIBAL Mechanical Gaming Keyboard MX Black= £44.99
- 1 x Cougar 500M Optical Gaming Mouse - Black= £27.95
- 1 x Palit GeForce GTX 1060 Super Jetstream RGB 6144MB GDDR5 PCI-Express Graphics Card= £259.99
- 1 x EVGA Supernova GS 550W '80 Plus Gold' Modular Power Supply= £79.99
- 1 x BitFenix Alchemy Premium Modding LED Strip - Connect Green 12cm= £8.99
- 1 x Alpenföhn Brocken 2 CPU Cooler= £39.95
Total: £1,322.75
(includes shipping: £0.00)
The Corsair RMx and RMi are every bit as good as the EVGA G2/SF Leadex Gold units. There is no reason at all to avoid Corsair.
I wouldn't touch them.
Wow I somehow spectacularly missed out the 6600k CPU, back to the drawing board unless you want to up the budget lol
I quite like this build! Ill throw in the CPU obviously, not an issue.
I was worried about those RAM cards though. I put them in my basket... But are they more of a visual gimmick? They look amazing, but how do they perform? I've read some reviews and they seem to hold up well.
Let me know what you think.
I could be wrong, but I thought the K only came with a CPU cooler? And there was no difference with the non K?
correct me I am wrong![]()
