So it's fairly quiet then?
Had a loud fan in my last computer and it drove me nuts lol
Its a tight squeeze on mine as it's only 2mm shorter then the limit according to the specs but hopefully will be OK.
Hi there - I am considering getting the P400 case - are you completely against an AIO water cooler? I'm novice, but had thought anout the possibility. Your research seems to suggest there's nothing suitable...
While I find most PC components pretty unattractive, and would rather close them up behind a solid panel rather than windowed cases - that Phanteks cooler looks cool.
I was looking around and I'm drawn to this Scythe Mugen:-
NH-D14 is a very good cooler. It's only down side is all s have variable voltage fans except for the 2011 model which has PWM fans. Most motherboards support both so it's only a deal breaker if yours is one of the few that has only PWM control on CPU fan headers.
