Im getting so confused trawling through this thread looking at what i need haha.
Can someone give me a basic run down of excatly what steps need to be taken and what products to use.
There's no one right answer, it depends on your preferences and to some extent, the color of the vehicle and the look you want to achieve.
Yes. Think of snow-foam as a pre-wash.If i buy snowfoam will i need to shampoo as well?
Would it be foam, wash (shouldi buy i serpeate shampoo or wash with the foam on?) rinse it then clay? (decent clay to buy?) straight from clay to polish? Then Wax?
I tend to foam, rinse, wash, rinse, dry.
If you need to clay/polish/seal/wax then as above, but before drying you'd clay, polish, seal and wax in that order.
Decent tyre dressing and wheel cleaner to?
Meguires Endurance Tyre Gel is my preferred choice for longevity, I sometimes use Auto Glym Instant Tyre Dressing for a quick top-up between applications of Megs.
Wheel cleaner I tend to use Bilberry wheel cleaner.
