- 11 Sep 2013
Given above.[TW]Fox;29940716 said:Citation needed.
Given above.
Absolute load of rubbish. Could be one of a number of things but a vacuum leak is the normal suspect. Check all your air hoses are in place correctly, have no tears and are tight. Better still, get the garage to pull their finger out and do it.
Given above.
A number of them, branches of Morrisons in particular, have been done by Trading Standards because their staff had fiddled with the fuel. They had been syphoning it off to sell out the back alley and bulking the main tanks with a variety of other stuff.
What would you like, then?I don't see a citation. I see you posting more words but no sources.
Considering the demands you're placing on people in the Semenya thread I think that's a bit rich.
What would you consider reputable enough?A simple link to a reputable site or article.
I can put you in touch with the TSO, perhaps, but it's not up to me whether he goes into detail about it.
I can ask around the various newspapers of Harrow and Brent, to see if their archives from about 2001 are available?
I doubt the companies involved would care to supply details of their own prosecuting, though. Same for any of their staff who might have been sacked as a result.
Difference is that the other thread is full of arguments based on some peoples' opinions of information they don't actually have, which they present as indisputable facts that are the only possible defining answer to a question of opinion and morality...You tell me! I'm just asking for what you're asking for elsewhere but failing to provide.
TBH, 2001 doesn't seem so long ago to me, but that probably means I'm just getting old...So this was 15 years ago? Hardly proof it's a current issue is it then?
Not when these people and those people are the same...[TW]Fox;29944301 said:There is a huge difference between the idea that people who work in Supermarket filling stations are stealing fuel and substituting it with random stuff and the common problem HMRC have with people inappropriately using red diesel etc.
I only mentioned it in passing... kinda like you do with anecdotes. It was never intended to be a watertight prosecution case on the high court of the internet, or anything...[TW]Fox;29944301 said:'My mate said' is literally the worst type of anecdote ever for a discussion like this - there is nothing to support it and the concept itself seems so far fetched as to be unbelievable.
I've got a 325i (3.0 N53, not the 2.5 N52) and I've used Tesco fuel loads of times. Never had any issue with that or any other kind of fuel.
Did you ever get anywhere with this problem?
Bet they're not impressed that the injectors are £210 each. Even with trade discount they've got to be £150 each.
