Deleted member 651465
Despite your request, I'm moving the thread to motors because you'll get better advice
Lol oh deary me... Just realised this is another Trixibug thread. You should get advice before buying cars, and listen to it. You're worse than I am...![]()
How could it pass an mot with no horn (Disconnected horn)?
You bought a 13 year old Ford ka. What did you really expect.
- Wiring to radiator fan cut/disconnected
- Faulty engine thermostat
- Leaking coolant pipes
- Side light out - fixed
- Disconnected horn
- Engine warning light for Lamba sensor - fixed but still a warning light
- Drivers side speaker w/no output then no sterio at all
- Interior light not working
- Aerial broken - fixed
- Wing mirrors changing back to stock - fixed
Edit: there is a much MUCH bigger story to all this but I didnt want to go too much into it and boil every ones heads![]()
We were considering Trading Standards - there has been a lot more going on with this car than the above, I just wanted to keep the OP short
Second hand ones don't, they just need to be "as described"
SOGA doesn't cover wear and tear either.
Unless the dealer described the problems as part of the sale, then they need to be sorted under SOGA.
It's a lot different if you take a finance agreement though.
A dealer needs the car to be suitable for the road - ie, it'll pass an MOT. The horn not working is a fail ... Or am I totally wrong here?!
Depends whether the Dealer has sold it with a new full MOT or not.
If not then the Dealer will argue that he didn't know that the horn didn't work, but should have no problem in fixing it.
Fair enough, I guess proving [insert non essential car part here] was broken at the point of sale is pretty difficult to do regardless!![]()
Pretty much why there are companies making money offering cheap third party warranties on behalf of dealers and giving people the run around.
Looking for second hand cars was the worst experience for me until i started to look privately.
http://www.reactiongifs.com/r/ozpp.gif[IMG][/QUOTE]
Yep! Well, maybe... I mean, I like to think I have enough sense to not buy a Ford Ka in the first place. Let alone pay about four times too much for one. :D
Also your gif game is weak, find better ones. ;)
Also your gif game is weak, find better ones.![]()
write a letter to the garage stating that it isn't fit for purpose
