Caporegime
- 8 Jan 2004
- Rutland
It's sensible to buy all the DDR3 you're likely to need now but for a DDR4 system prices will get lower and speeds increase so no rush.
But why not wait the few years until you actually need it?
I have done this, I sent £165 on 16GB of team group 3733mhz ddr4 ram and for gaming and normal pc stuff I couldn't tell the difference. In the end I sold it for a massive loss after 3 months (£80) and went with 32GB of 2400mhz, overclocked it to 2858mhz and I can't tell the difference.
In a similar situation here, going to buy new memory, simple Corsair Vengeance Pro 2400MHz 2x8gb kit is fine. But I can get a 32gb 2400MHz 8x8 kit for just £60 more.
I don't have any need for more than 16gb. I can max out my Gene with 32gb and occupy the slots, which is probably the main reason, looks and epeen, well looks as empty slots are irritating me.
I like to try things every so often but would have to look hard to find a use for 32gb I guess, most likely will end up again playing with my old DSLR, ripping HD movies for a NAS library, but if I can find something to play with for even a few months that I would enjoy trying that used 32gb then I would give it a go.
Currently though, I can't think of anything, as much as I can afford it now, by the time I could use 32gb we will most likely be on DDR8 with 8 core Pentiums
Yet I'm still tempted to just drop that extra £60 bucks for the "just in case one day" that usually never happen.
16GB is pretty comfortable and I don't see needing more in a hurry any time soon for gaming that said I'm eyeing up more as lately I've been using a RAM drive for capturing footage while playing as it has the smallest performance impact and more would allow me to capture longer and/or higher quality.
I used to "multibox" some games which made 16GB highly desirable to have - performance suffered significantly with anything less especially when swapping between clients.
Kinda funny reading the word 'waste' used in terms of having too much. People throw hundreds of pounds down the pan on GPU's without really thinking about it.
deus ex mankind divided recommended specs, i'll let you know how much usage we get upto when it releases lol
Recommended Requirements
- OS: Windows 10 64-bit
- Processor: Intel Core i7-3770K or AMD FX 8350 Wraith
- Memory: 16 GB RAM
- Graphics: AMD Radeon RX 480 - 1920 x 1080 or NVIDIA GTX 970 - 1920 x 1080
- Storage: 55 GB available space
- Additional Notes: 55GB HD space includes DLC
