Upgrade from i3 6100
Incorrect.
The 6600k base clock is 3.5ghz it boost to 3.9ghz making it 200mhz faster than the 6100.
http://ark.intel.com/products/88191/Intel-Core-i5-6600K-Processor-6M-Cache-up-to-3_90-GHz
A lot of different information in this thread
I guess I just want to know if getting a 6600k without overclocking it for now will be a good idea.... The main thing I'm struggling with is when I'm playing games and have other applications open I'm notcing my CPU usage maxing out which sometimes causes lag spikes, a better CPU would stop this from happening? I do also only have 8GB RAM at the moment but I never really seem RAM usage maxing out
The Xeons are rarely on compatability lists, should work anyway.
And the i3/i5 situation is a fallacy, there will be absolute minimum games where an i5 will perform worse, especially when you consider boost.
Intel changed things with Skylake so you need a server chipset now.
Edit!!
What graphics card does the OP have??
well I went from an i3 6100 to a 6400..im seeing very little in way of framerate increase tbh running a 1060,seems the extra clock speed of the 6100 offsets the extra cores of the 6400 somewhat..im saving for a z170 board tho so I can OC it tho.
I'd get a Z17o mobo and OC the i3 with your first bit of the budget, and then see how you go with potentially picking up a K chip later down the line when you have some more money to spend.
How many apps do you need open when gaming?
