Caporegime
- 18 Sep 2009
- Dormanstown.
Sounds like a good idea I think. I should be able to overclock my i3 on that for the time being ?
No.
***Edit*** I got it the wrong way around. Your i3 6100 is 200mhz faster than the 6600k (i3 6100 is 3.7Ghz, 6600k is 3.5Ghz) so in games that don't make use of the extra cores you will actually lose performance.
Incorrect.
The 6600k base clock is 3.5ghz it boost to 3.9ghz making it 200mhz faster than the 6100.
http://ark.intel.com/products/88191/Intel-Core-i5-6600K-Processor-6M-Cache-up-to-3_90-GHz
A lot of different information in this thread
Yes.
I am only when I have other apps open
Since when can you overclock i3's?
I would just close down other apps before gaming.
With your budget your not going to get a satisfactory upgrade.
The Xeons are rarely on compatability lists, should work anyway.
And the i3/i5 situation is a fallacy, there will be absolute minimum games where an i5 will perform worse, especially when you consider boost.
