I've been looking at the saloon, why does going for the Avant matter?
For your last sentence which car are you talking about sorry?
You'll probably be able to give me a bunch of differences, but it feels like it's essentially the two generations newer version of my car. It might just be in my head, but I'm sure I'd get bored of it quicker than an M3 or an S/RS5.
I'd rather a 12 plate S5 than a 12 plate M3 E92...IMO but I am biased towards audis.![]()
You're kidding......
snip
It doesn't really, buy the one you prefer, but the Avant offers extra practicality and tends to hold its price better (and costs more) because of that.
The RS4, it hides its speed and actually doesn't put out the BHP Audi claims and suffers from coking which does impact that performance. It can be fixed, but it needs work and costs and still doesn't put out 414bhp I believe.
[TW]Fox;29965639 said:You may tire of it sooner than an M3 or an RS4 but a S5 is a one generation newer competitor of what you have now* so why would that be any more suitable than an F30?
*There is more to it than that obviously but then you seem to ignore the fact the F30 is a completely different car to an E46 and shares nothing with it.
18 months ago I made the change from E46 330Ci to E92 M3. Like you I wanted the car to be a nice place to spend time, and whilst I wouldn't say that an LCI E92 M3 has a better interior overall than as RS4/S5, features such as the infotainment are considerably better (the CIC iDrive is fantastic) in the M3 and being a BMW fanboy at heart it was a clear winner for me. I won't write much more because to be honest it's all been covered above by people like Gibbo.
What part of London do you live in? Happy to meet up if you're local/don't mind travelling a bit to take you out for a spin in mine, although I can't guarantee I won't spend the entire time trying to convince you to increase your budget by £5k and buy mine
Feel free to email me through trust with any questions about going from E46 330Ci to E92 M3, will be happy to answer as best I can![]()
For £25k it has to be an LCI E92 M3 DCT. Good options to look out for are EDC, BMW Loudspeaker hifi, heated seats and comfort access. They're very well specced to begin with. Unfortunately £25k won't get you a Competition Pack car, unless you find a high mileage example.
But you'd still recommend one? I've read about the coking issue but most of the ones i've looked at (and the one I test drove, according to the dealer) had that fixed so hopefully it wouldn't be an issue If i went for the RS4.
It just "feels" like essentially the same car to me. It is basically the same model, but two generations newer.
The S5 also has a much nicer interior, like the seats for example, and I do really want a car that's a pleasure to be in. In my head it doesn't make a lot of sense to go with the newer version of my car, it's either an S5 that can be tuned, or do the BMW properly and go for the M3.
The difference is the 335i was better than the S5, so even more reason to bin the A5 idea, awful things.
