How long has that been over?
Was on 57850 or so when I bought it. It's done well to be fair, only expense outside of tyres, servicing and brakes has been a clutch and DMF and even so, they're consumables anyway.Do you have hands the size of a child? Because it's easy then![]()
I think last night I just ticked over 70k miles since I got my car. On 127900 ish nowWas on 57850 or so when I bought it. It's done well to be fair, only expense outside of tyres, servicing and brakes has been a clutch and DMF and even so, they're consumables anyway.
what car?
What sort of tool do you need? Cant it be done by stretching, straining, swearing, and ruining the circulation to your fingers?
I thought that was how its done!![]()
Had egr deleted.
One of these things supposedly. https://www.amazon.co.uk/Laser-5208-Auxillary-Belt-Tensioner/dp/B005I503AO
It's impossible without having a way to compress the tensioner. People on forums have made tools from cut down bolts but I figured I'd just get the right tool and save me some effort.
Just annoyingly its coming tomorrow, and not today when I actually did 99% of the work.
This guys method seems decent, however I figured I'll just be patient.
[TW]Fox;29968114 said:How much have you spent on this car since buying it?![]()
