Wunkley, you never fail with these things!
Do you leave Gsync to cap the frame rate, or do you cap a couple of FPS below the 100?
I am quite particular about getting things to work properly, or as best as they can. I'm a picky ****er. These days I tend to leave gsync to do its thing. I see very little difference personally in terms of input lag by capping a few frames under like some people do. I think it depends on the game though.
For some games I do cap 1 frame under the refresh rate using RTSS to help with overall smoothness which a handful of games benefit from sometimes.
Also, these days I tend to max out my x34 at 85hz. Not many recent games I currently play will maintain 100fps at max settings, and keeping at 85 helps to mitigate the scan line issue these overclocked panels that the x34 and Asus pg348q have (if you can keep your fps as close to your refresh rate as possible it basically cures the scan lines problem - I've got a whole post somewhere on here about that).
My SLI 980Tis can pretty much maintain 85fps in everything. And I feel there's not a massive difference between 85fps/hz and 100fps/hz in terms of overall motion clarity etc on this monitor.
