Yours is the same as his bar a remap (inc exhaust + DPF & EGR removal) and lowering springs.![]()
Anything else is visual and makes no difference to the points he made.
Slightly lower mileage iirc, but his was so badly abused that it needs a new clutch and DMF, the DPF was knackered and the paint doesn't match - which easily makes up for the mileage difference. It's since been modified which does not increase value on cars like this - I'd say if they were put up for sale side by side then mine would be the more appealing car to most buyers.
Mine was 5800 quid and is faultless, immaculate and was bought from the original owner with full mazda history. dealers were advertising lower mileage ones of the same age with a warranty for 7k. If there's one thing I can talk about with these, it's the value of them as I spent a decent amount of time looking around an understanding the market.
eibach pro are fine!
I need it.
