Grid Autosport Benchmark Thread
Caporegime
12 Jul 2007
United Kingdom
[email protected]
7990@1175/1700Mhz
15.4 Beta
1080P
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Benchmark Mode Results -->
<benchmark directx11_feature_level="11.0" instruction_set="AVX" author="Matt" date="15:38:53 on 14/05/2015" machine="Matthew">
<totals races="1" total_time="00:02:33" total_race_time="00:02:26" race_time="00:02:26" />
<fps_race min_fps="100.564209" max_fps="156.954910" av_fps="122.321968" min_fps_ms="9.943895" max_fps_ms="6.371256" av_fps_ms="8.175146" />
<fps_total min_fps="100.564209" max_fps="156.954910" av_fps="122.321968" min_fps_ms="9.943895" max_fps_ms="6.371256" av_fps_ms="8.175146" />
<track index="1" numInRotation="1" totalProfiled="1">
<results samples="17924" min_fps="100.564209" max_fps="156.954910" av_fps="122.321968" min_fps_ms="9.943895" max_fps_ms="6.371256" av_fps_ms="8.175146" battery_percentage_used="0" />
<settings name="san_francisco" route="route_0">
<car name="sls" livery="user" />
<car name="320" livery="06" />
<car name="sls" livery="04" />
<car name="320" livery="user" />
<car name="sls" livery="08" />
<car name="g40" livery="user" />
<car name="sls" livery="03" />
<car name="320" livery="01" />
</settings>
</track>
<hardware_settings_config version="21" deviceId="0x679B">
<cpu>
<threadStrategy workerMapFile="system/workerMap8Core.xml" forceFeedbackProcessor="6" dvdStorageProcessor="7" dataSetMonitorProcessor="4" renderProcessor="0" updateProcessor="2" fileStreamProcessor="5" />
</cpu>
<audio_card>
<dynamic_range value="high" />
<eq value="flat" />
<voice_chat enabled="true" />
<push_to_talk enabled="false" />
<ai_count value="high" />
<voice_count value="high" />
</audio_card>
<graphics_card firstBoot="true" rating="4">
<directx forcedx10="false" />
<eyefinity force="" osd="" />
<stereo enabled="false" separation="0.015" convergence="0.5" />
<advanced forward="true" global_illumination="true" />
<intel tree_aoit="false" particle_avsm="false" />
<resolution width="1920" height="1080" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
<refreshRate rate="59" />
</resolution>
<gamma level="0.8" />
<avsm enabled="true" />
</graphics_card>
<shadows enabled="true" size="4096" maskQuality="2" particles="true" />
<advanced_fog enabled="true" />
<particles enabled="true" wind="true" dynamicRes="false" lowResScalar="2" nearFadeBias="0" />
<crowd enabled="true" detail="4" />
<cloth enabled="true" />
<groundcover mode="ultra" clutter="true" />
<objects lod="1.5" maxlod="0" />
<trees lod="3.0" maxlod="0" meshes="true" meshes_in_all_passes="true" />
<vehicles characterQuality="4" lodQuality="3" />
<track quality="2" />
<envmap faces="6" size="1024" drawallobjects="true" scaleminsize="0.1" mindistance="200.0" />
<water update="true" detail="3" scale="2" drawallobjects="true" tessellation="true" />
<mirrors enabled="true" width="1024" height="256" car_maxlod="0" />
<skidmarks enabled="true" />
<dynamic_ambient_occ enabled="true" quality="3" />
<dynamic_ambient_occ_soft enabled="true" />
<night_lighting volumes="true" lights="0" shadows="true" onlyHeadlights="false" shadowSize="2048" />
<textures resolution="2" />
<shaders quality="2" low_quality="false" />
<anisotropic min="4" max="16" />
<physics environmentalDamage="true" vehicleDamage="true" />
<input device_type="auto" />
<motion enabled="true" ip="dbox" port="20777" delay="1" extradata="0" />
<second_screen quality="2" />
<oculus enabled="true" headMovement="true" chromatic="true" timeWarp="true" vignette="true" overdrive="true" convergence="1.0" />
</hardware_settings_config>
</benchmark>
9 Nov 2005
Southampton
Q9300 @ 3Ghz
R7 265 @ 1050/1400
15.200.1023.0000 on Windows 10 preview
1920x1200
"Ultra" preset
55.8fps avg.
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="sclow" date="11:57:56 on 14/05/2015" machine="WIN-MJ2SVI69CJ7">
<totals races="1" total_time="00:02:32" total_race_time="00:02:25" race_time="00:02:25" />
<fps_race min_fps="43.194820" max_fps="80.852013" av_fps="55.861870" min_fps_ms="23.150925" max_fps_ms="12.368276" av_fps_ms="17.901299" />
<fps_total min_fps="43.194820" max_fps="80.852013" av_fps="55.861870" min_fps_ms="23.150925" max_fps_ms="12.368276" av_fps_ms="17.901299" />
<results samples="8138" min_fps="43.194820" max_fps="80.852013" av_fps="55.861870" min_fps_ms="23.150925" max_fps_ms="12.368276" av_fps_ms="17.901299" battery_percentage_used="0" />
</settings>
</track>
<hardware_settings_config version="21" deviceId="0x6819">
<cpu>
<threadStrategy workerMapFile="system/workerMap4Core.xml" forceFeedbackProcessor="3" dvdStorageProcessor="3" dataSetMonitorProcessor="1" renderProcessor="0" updateProcessor="2" fileStreamProcessor="3" />
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
<advanced forward="false" global_illumination="false" />
<resolution width="1920" height="1200" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
<refreshRate rate="60" />
</resolution>
</graphics_card>
<mirrors enabled="false" width="256" height="64" car_maxlod="4" />
<dynamic_ambient_occ_soft enabled="false" />
</benchmark>
Another game that runs miles better on Windows 10 preview! ;)
Man of Honour
OP
21 May 2012
Dalek flagship
Q9300 @ 3Ghz
R7 265 @ 1050/1400
1920x1200
"Ultra" preset
55.8fps avg.
</settings>
</track>
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
</resolution>
</graphics_card>
</benchmark>
Could you check your settings please.:)
I have marked the ones in bold.:)
9 Nov 2005
Southampton
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="sclow" date="16:07:48 on 14/05/2015" machine="WIN-MJ2SVI69CJ7">
<totals races="1" total_time="00:02:28" total_race_time="00:02:21" race_time="00:02:21" />
<fps_race min_fps="36.059799" max_fps="61.045601" av_fps="46.637985" min_fps_ms="27.731712" max_fps_ms="16.381197" av_fps_ms="21.441750" />
<fps_total min_fps="36.059799" max_fps="61.045601" av_fps="46.637985" min_fps_ms="27.731712" max_fps_ms="16.381197" av_fps_ms="21.441750" />
<results samples="6600" min_fps="36.059799" max_fps="61.045601" av_fps="46.637985" min_fps_ms="27.731712" max_fps_ms="16.381197" av_fps_ms="21.441750" battery_percentage_used="0" />
</settings>
</track>
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
</resolution>
</graphics_card>
</benchmark>
Revised config is ~46.6fps, found another two options were not activated by the "ultra" preset, besides the two you highlighted earlier... Which from memory, sounds more like the figure I vaguely recall for Win8.1 :)
Man of Honour
OP
21 May 2012
Dalek flagship
</settings>
</track>
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
</resolution>
</graphics_card>
</benchmark>
Thanks and on the scoreboard.:)
Caporegime
12 Jul 2007
United Kingdom
5960X @4.9Ghz
2x 295x2 @1175/1625Mhz
Catalyst 15.5 Beta
3840x2160P
<benchmark directx11_feature_level="11.0" instruction_set="AVX" author="Matt" date="09:44:26 on 05/06/2015" machine="Matthew">
<totals races="1" total_time="00:02:27" total_race_time="00:02:20" race_time="00:02:20" />
<fps_race min_fps="122.502319" max_fps="204.725754" av_fps="158.028824" min_fps_ms="8.163111" max_fps_ms="4.884583" av_fps_ms="6.327960" />
<fps_total min_fps="122.502319" max_fps="204.725754" av_fps="158.028824" min_fps_ms="8.163111" max_fps_ms="4.884583" av_fps_ms="6.327960" />
<results samples="22233" min_fps="122.502319" max_fps="204.725754" av_fps="158.028824" min_fps_ms="8.163111" max_fps_ms="4.884583" av_fps_ms="6.327960" battery_percentage_used="0" />
</settings>
</track>
<hardware_settings_config version="21" deviceId="0x67B9">
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
<resolution width="3840" height="2160" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
</resolution>
</graphics_card>
</benchmark>
Man of Honour
OP
21 May 2012
Dalek flagship
Single TitanX @1481/2002
5960X @4.5
353.06 Drivers.
2160p
<?xml version="1.0" encoding="UTF-8"?>
-<benchmark machine="HAL" date="15:22:35 on 06/06/2015" author="Keve" instruction_set="AVX" directx11_feature_level="11.0">
<totals race_time="00:02:21" total_race_time="00:02:21" total_time="00:02:28" races="1"/>
<fps_race av_fps_ms="12.559039" max_fps_ms="10.552100" min_fps_ms="15.286594" av_fps="79.623924" max_fps="94.767868" min_fps="65.416794"/>
<fps_total av_fps_ms="12.559039" max_fps_ms="10.552100" min_fps_ms="15.286594" av_fps="79.623924" max_fps="94.767868" min_fps="65.416794"/>
-<track totalProfiled="1" numInRotation="1" index="1">
<results av_fps_ms="12.559039" max_fps_ms="10.552100" min_fps_ms="15.286594" av_fps="79.623924" max_fps="94.767868" min_fps="65.416794" battery_percentage_used="0" samples="11237"/>
-<settings route="route_0" name="san_francisco">
<car name="sls" livery="user"/>
<car name="320" livery="06"/>
<car name="sls" livery="04"/>
<car name="320" livery="user"/>
<car name="sls" livery="08"/>
<car name="g40" livery="user"/>
<car name="sls" livery="03"/>
<car name="320" livery="01"/>
</settings>
</track>
-<hardware_settings_config deviceId="0x17C2" version="21">
-<cpu>
<threadStrategy fileStreamProcessor="5" updateProcessor="2" renderProcessor="0" dataSetMonitorProcessor="4" dvdStorageProcessor="7" forceFeedbackProcessor="6" workerMapFile="system/workerMap8Core.xml"/>
</cpu>
-<audio_card>
<dynamic_range value="high"/>
<eq value="flat"/>
<voice_chat enabled="true"/>
<push_to_talk enabled="false"/>
<ai_count value="high"/>
<voice_count value="high"/>
</audio_card>
-<graphics_card firstBoot="true" rating="3">
<directx forcedx10="false"/>
<eyefinity osd="" force=""/>
<stereo enabled="false" convergence="0.5" separation="0.015"/>
<advanced global_illumination="true" forward="true"/>
<intel particle_avsm="false" tree_aoit="false"/>
-<resolution multisampling="8xmsaa" vsync="0" fullscreen="true" aspect="auto" height="2160" width="3840">
<refreshRate rate="29"/>
</resolution>
<gamma level="0.8"/>
<avsm enabled="true"/>
</graphics_card>
<shadows enabled="true" particles="true" maskQuality="2" size="4096"/>
<advanced_fog enabled="true"/>
<particles enabled="true" nearFadeBias="0" lowResScalar="2" dynamicRes="false" wind="true"/>
<crowd enabled="true" detail="4"/>
<cloth enabled="true"/>
<groundcover clutter="true" mode="ultra"/>
<objects maxlod="0" lod="1.5"/>
<trees maxlod="0" lod="3.0" meshes_in_all_passes="true" meshes="true"/>
<vehicles lodQuality="3" characterQuality="4"/>
<track quality="2"/>
<envmap size="1024" mindistance="200.0" scaleminsize="0.1" drawallobjects="true" faces="6"/>
<water detail="3" drawallobjects="true" tessellation="true" scale="2" update="true"/>
<mirrors enabled="true" height="256" width="1024" car_maxlod="0"/>
<skidmarks enabled="true"/>
<dynamic_ambient_occ enabled="true" quality="3"/>
<dynamic_ambient_occ_soft enabled="true"/>
<night_lighting shadowSize="2048" onlyHeadlights="false" shadows="true" lights="0" volumes="true"/>
<textures resolution="2"/>
<shaders quality="2" low_quality="false"/>
<anisotropic max="16" min="4"/>
<physics vehicleDamage="true" environmentalDamage="true"/>
<input device_type="auto"/>
<motion enabled="true" extradata="0" delay="1" port="20777" ip="dbox"/>
<second_screen quality="2"/>
<oculus enabled="true" convergence="1.0" overdrive="true" vignette="true" timeWarp="true" chromatic="true" headMovement="true"/>
</benchmark>
1080p
-<benchmark machine="HAL" date="15:13:11 on 06/06/2015" author="Keve" instruction_set="AVX" directx11_feature_level="11.0">
<totals race_time="00:02:24" total_race_time="00:02:24" total_time="00:02:31" races="1"/>
<fps_race av_fps_ms="6.050462" max_fps_ms="4.902332" min_fps_ms="7.235020" av_fps="165.276627" max_fps="203.984558" min_fps="138.216614"/>
<fps_total av_fps_ms="6.050462" max_fps_ms="4.902332" min_fps_ms="7.235020" av_fps="165.276627" max_fps="203.984558" min_fps="138.216614"/>
<results av_fps_ms="6.050462" max_fps_ms="4.902332" min_fps_ms="7.235020" av_fps="165.276627" max_fps="203.984558" min_fps="138.216614" battery_percentage_used="0" samples="23896"/>
</settings>
</track>
-<cpu>
</cpu>
-<audio_card>
<eq value="flat"/>
</audio_card>
-<resolution multisampling="8xmsaa" vsync="0" fullscreen="true" aspect="auto" height="1080" width="1920">
<refreshRate rate="59"/>
</resolution>
</graphics_card>
</benchmark>
7 Aug 2014
3570k @4.0GHz
MSI R9 390 @1040/1500MHz
Crimson 16.9.1
1920x1080
Average 97.03fps
Minimum 75.83fps
<benchmark machine="MONSTERBOX" date="00:11:41 on 14/09/2016" author="robxg" instruction_set="AVX" directx11_feature_level="11.0">
<totals race_time="00:02:18" total_race_time="00:02:18" total_time="00:02:25" races="1"/>
<fps_race av_fps_ms="10.306161" max_fps_ms="7.773311" min_fps_ms="13.186662" av_fps="97.029343" max_fps="128.645309" min_fps="75.834206"/>
<fps_total av_fps_ms="10.306161" max_fps_ms="7.773311" min_fps_ms="13.186662" av_fps="97.029343" max_fps="128.645309" min_fps="75.834206"/>
<results av_fps_ms="10.306161" max_fps_ms="7.773311" min_fps_ms="13.186662" av_fps="97.029343" max_fps="128.645309" min_fps="75.834206" battery_percentage_used="0" samples="13476"/>
</settings>
</track>
<hardware_settings_config deviceId="0x67B1" version="21">
<cpu>
<threadStrategy fileStreamProcessor="3" updateProcessor="2" renderProcessor="0" dataSetMonitorProcessor="1" dvdStorageProcessor="3" forceFeedbackProcessor="3" workerMapFile="system/workerMap4Core.xml"/>
</cpu>
<audio_card>
<eq value="flat"/>
</audio_card>
<graphics_card rating="4" firstBoot="true">
</resolution>
</graphics_card>
</benchmark>
20 Nov 2005
Redditch
Been a while.....
i7 4770 @ 4.5ghz
Gigabyte G1 980Ti 1515/4000mhz
Drivers 372.54
1440p
Av 120.38
Min 97.9
Max 142.30
<benchmark directx11_feature_level="11.0" instruction_set="AVX" author="Rob Williams" date="01:24:51 on 14/09/2016" machine="TheBeast">
<fps_race min_fps="97.959732" max_fps="142.302673" av_fps="120.382652" min_fps_ms="10.208276" max_fps_ms="7.027275" av_fps_ms="8.306845" />
<fps_total min_fps="97.959732" max_fps="142.302673" av_fps="120.382652" min_fps_ms="10.208276" max_fps_ms="7.027275" av_fps_ms="8.306845" />
<results samples="17625" min_fps="97.959732" max_fps="142.302673" av_fps="120.382652" min_fps_ms="10.208276" max_fps_ms="7.027275" av_fps_ms="8.306845" battery_percentage_used="0" />
</settings>
</track>
<hardware_settings_config version="21" deviceId="0x17C8">
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
<resolution width="2560" height="1440" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
<refreshRate rate="144" />
</resolution>
</graphics_card>
</benchmark>
