Music randomly jumping volume!? :(
20 Aug 2007
Solihull
Hi guys,
wondering if anyone had any idea as to what's going on with my audio atm..
PC spec in my sig, speaks are logitech x540 5.1 speakers, recently I've noticed that my music will randomly change volume/cut up and down - it's very annoying and I can't work out why it's happening.
I use deezer normally, it does the same in chrome and edge - helpppp! :(
Cheers,
Jamie
3spooky5me
Kinda sounding like an issue with the service rather than your PC. Seeing as it seems ok offline and with movies/YouTube.
Sorry I only just noticed you said deezer in the op. Didn't recognise the name.
Idk why it would be doing it though, it's so frustrating D: only started happening in last few days - doesn't happen on my laptop or phone with deezer.. D:
Mine did the same - its the remote control that did it. If you press the volume knob down it sometimes sorts it for a while.
I think you'll need to change the potentiometer in the remote control but I just gave them to a mate and bought myself a headset lol.
Wait you mean the speakers? I'm using the deezer app for windows now on my PC and it seems to be fine o.o
Mine doesn't have a remote control :O never has, just has the volume control fixed onto a long wire :o
Sorry - remote control was the wrong term to use, it's the volume control knob on the long wire that was iffy for me.
Brain was a bit frazzled after getting pwnt on CS GO last night :o:p
