- 25 Sep 2011
- Cambs
hi guys
right, got a question that id rather ask, before i actually try it...
I have a HP Proliant Enterprise server, with 7x 1tb hard drives installed..
They are set as a raid 1 array..
So the fiirst 3 drives are Mirrored with the Last 3..
giving 3 volumes, 3tb of total useable space etc.
if you understand what i mean...
(this is not my actual server photo, just to demonstrate what i mean)
Now, say Drive 1 and 4 are full up (the first RAID 1 array), can i just remove them both, and insert fresh par of hard drives and set as RAID 1, and keep the original pair aside for when i need to access its data again, then smply pull the new two out, and slide the old two drives back in, and re-access my data?
it may sound like a stupid question, But i dont know the answer..
i dont want to take the pair of drives out and fit fresh ones, and then not be able to put the old pair back in, and re-access my data again.
Just incase i have to "re-initialise" the drives each time i take them out and put them back in, because obviously, re-initialising them, wipes the data)
cheers
cheers
