Well... it pretty tricky to put your knee down on the SV, a lot of my mates and people who own them said that to me when I asked them whenever they've done it.Sounds like you're not hanging off or sticking your leg out? If you're scraping your peg then you should be more than close enough to scrape your knee if you want.
Unless it has those freaky long hero blobs?
My brother's Bonneville pegs will scrape before knee down but that's just the style of the bike. Maybe yours is the same, dunno
He's just having a bit of fun![]()
V-Twin problems![]()
Not lost any screws from yours yet Kreeeee?![]()
So where's the video?
From my Triple? Nope, even throwing it down the road budged any bolts
On my SV650 I was forever losing the cheesy Suzuki fairing bolts until I used some loctite.
Well the engine covers match the engine so they keep the looks of the bike, and the axle sliders are not obvious either.
You can get frame sliders instead of crash bungs but I doubt they work as well.
I have the crash bungs on mine which sit nicely between the fairings, plus some crash bungs on my forks. I've just seen some nasty engine cover ones which kind of put me off. Worth it if they match though.
Nice one, thanks - a quick lock tank bag is the only option for the Tuono really, plastic tank! They're not cheap, £160 but I'd rather have something decent.
