Verdict, paraffin is **** for cleaning chains! Unless you can take the chain off and soak it, I'll stick to chain cleaner.
I used it yesterday to clean my chain and it was spotless after 30 seconds.
Apply roughly with a toothbrush on all faces, then the use a rag on the chain while spinning the wheel for 10 seconds.
No thanks Jeff.
