The guys on our Alps Whatsapp group have made me change my mind about the MT-10 SP. I think they just like toying with me![]()
Both the Yamaha crossplane and the Aprilia V4 engines make funny things happen in my pants.
The new engine produces an additional 6bhp, bringing peak power up to a quoted 74bhp at 8000rpm. Torque is also increased, up to 52ftlb at 6750rpm. The new engine also features a second counter balancer shaft to reduce vibrations. A new 50mm throttle body gets rid of the mechanical linkage to the throttle for improved throttle response.
New engine highlights
Increased power & torque of 74 hp & 71.0 Nm
An additional 1000 rpm of usable power
Reduced oscillating masses for lower vibrations
New intake resonator for improved response at low rpm
Long service intervals & low fuel consumption
Single overhead cam =>Double spark plugs
Large bore & short stroke [105 mm & 80 mm]
Forged aluminium piston
Cutting edge ride-by-wire electronics
The husky 701 has received a huge update for 2017 - new engine, more power and torque. Definitely not annoyed that I bought a 2016 model in May...
Should've seen it coming to be fair. That's the same engine as this year's Duke 690 isn't it?
Speaking of KTM. They need a naked between the Duke 690 and 1290. There's a massive chasm in between those bikes.
Speaking of KTM. They need a naked between the Duke 690 and 1290. There's a massive chasm in between those bikes. But they are priced quite weird.
Probably a similar feeling to all the people that bought brand new MT10s not that long ago![]()
It's not just down to emissions, sound levels are also much more tightly controlled with a new test as part of Euro4 regs so that'll play a part in them putting massive hideous end cans on.
Any videos of the sound or is that just reviews?
Stick on an akra can and you're good.
The new Tuono has had the sound neutered a lot, which was one of the big selling points for me
I'll be upgrading in spring too unless I find a stellar deal over winter.
The MT-10 SP and an older Tuono are at the top of my list.
You need to fit a full system on the new bikes to make any difference to the sound.
The volume is measured at 89dB now instead of the 104dB of the older ones.
The first thing i would do is change the end can and decat ... so the new euro 4/5 shiz makes little difference . I have yet to ride the Mt10 and i do prefer twins or v4 . My heart says Tuono but my wallet says Mt10
