*** The Official Destiny Thread (now includes 2.0 and TTK) ***
Code:
1. OweO 380+ Yes
2. Greeboth 380+ Yes
3. Middgen Titan 377 Yes
4. Davie Yes
5. Chewie9967 Hunter 381 Some
6. Col_Jacko  Titan 365+  NO
7. Meths
8. TehBlueBear
9. Redrooster 380+ Yes
10. TX Yes
11. TX +1 No
12. MachM
I like to start by 7:30pm UK time as I'm a timezone ahead.
Assuming some people want to start a little later shall we say one is at 7:30 and one 8:30?
Wednesdays I get home earlier so I am happy with either time and in either group.
Code:
1. OweO 380+ Yes
2. Greeboth 380ish Yes Titan
4. Davie Yes
7. Meths
8. TehBlueBear
10. TX Yes
11. TX +1 No
12. MachM
I'll be running my titan for this so updated the above.
Code:
1. OweO 380+ Yes
4. Davie Yes
7. Meths
8. TehBlueBear
10. TX 384 Warlock Yes
11. TX +1 367 Titan No
12. MachM
Ok I've split the lists to make the times easier. If you have a preference and need to switch just update.
Code:
WotM Normal Mode Wednesday 7:30pm
1. OweO 380+ Yes Any
3. Middgen 377 Yes Titan
4. Davie Yes
5. Chewie9967 381 Some Hunter
6. Col_Jacko  365+ NO Titan
WotM Normal Mode Wednesday 8:30pm
1. Meths
2. TehBlueBear
3. Redrooster 380+ Yes
4. TX 384 Yes Warlock
5. TX +1 367 No Titan
6. MachM
Code:
1. OweO - 380+ - Yes - Any
2. Greeboth - 380ish - Yes - Titan
3. Middgen - 377 - Yes - Titan
4. Davie - Yes
5. Chewie9967 - 381 - Some - Hunter
6. Col_Jacko  - 365+ - NO - Titan
1. Meths
2. TehBluebear - 364 (still! :( ) - Some - Hunter
3. Redrooster - 380+ - Yes
4. TX - 384 - Yes - Warlock
5. TX +1 - 367 - No - Titan
6. MachM
Code:
4. Davie - Yes
1. Meths
6. MachM 364 - No - Titan or warlock (will have several days of grinding strikes to get LL up)
In fact, gonna run some strikes now. If people see me, feel free to join.
Ran my Titan through the raid and got the Outbreak Prime Quest again in my bid to get a second to infuse in to Chaos Dogma ready for HM. Not sure I will have time, especially with the COD Beta, but worth a shot to get it done.
With the new weapon drops I got my Warlock up to 384, really being held back by a 380 heavy and 376 Ghost :( pretty much everything else is in the 364-367 region. A little grind on bounties should see me get a vanguard and crucible package so fingers crossed.
Man I forgot what a drag the Thorn quest is with a titan! Still, usually get 5% per match using a void fusion on Supremacy.
Just shy of 378 now, but 371 boots are holding me back :(
Do you not have Atheons Epilogue or Word of Crota? If not a quick run of Crota HM might solve that :)
I got the quest pop last night. I plan to use either of the above (or my Yr Trials scout), void vacancy & my Zombie Apocalypse. At least deaths don't hold you back.
xur's selling exotic arm engrams NOT the legacy ones
And Trespasser! :D
Finally getting that trespasser! Gonna stock up on gauntlets for Tuesday easy ll to be obtained! Looking forward to the hard mode
Am I right in thinking if I buy some gauntlet engrams now, leave in the vault until HM and the increased light cap drops next week then they can decode higher than now? As my current gauntlets are 387 already so decoding now wont boost my LL.
