(gamegpu) Battlefield 1 Benchmarks
Min frames are even more important if they keep you in adaptive sync range as well... People seem to forget that and think it's only high fps that matters, my screen has a range of between 40 -144 for Freesync, I can frame cap say The Division at 120fps to keep at the upper end, dx12 makes sure my lower end mins are higher to keep from dropping too low
Why does that matter? It won't get any better.
Well it would matter if DX12 offered anything of note - like better visuals/effects.
What does DX12 actually do in BF1, other than hobble the Nvidia cards a bit and remove mgpu support?
it doesn't hobble anything does it ?
it helps performance of those cards that can utilise it
quite a difference
I'm sure it drastically improves framerates for people with weaker CPUs, which was always cited as one of the main benefits. I was using a Phenom II X6 earlier in the year and the Rise of the Tomb Raider DX12 patch boosted my minimum framerate by 33fps.
quite a difference
No, if you look at the benches in the OP, the framerate actually reduces on Nvidia cards (about 10% in some cases).
For example the 1080 and 1070 at 1440p.
Just meant that comparing dx12 vs dx12 doesn't make sense when one is performing better under dx11.
This - if you were , for example, a 1080 or 1070 owner with an i7 cpu why would you use DX12, as all it seems to do is reduce frames (minimums and average)?
In DX11 the Fury/Fury X and 1070 are all pretty much equal at 1440p. Then with Dx12 on, the 1070 just randomly loses 9fps whilst the Fury cards gain a couple.
aaaaand, 1080 kicking ass in DX11 and 12, it is faster is it not :confused:
He said nothing of the 1080 not kicking ass its expected as its newer gen and more expensive.
Its seems that for you personally only the fastest card counts as kicking ass, many don't share that view.
so many varibles in bf.
single player vs mp worlds apart.
game mode and player size.
some maps with different weather conditions on 64 man maps can be 20 fps different to others.
also min fps which many dont measure but probably the most important.
